Newbie needing help with Knock and timing map
Old Apr 11, 2013 | 09:48 AM
  #31
yositoco's Avatar
Thanks for the input. I will be changing the pump this weekend and testing again.
will update then
Old Apr 15, 2013 | 10:49 AM
  #32
yositoco's Avatar
It looks like my car had one of those ebay fuel pumps. I couldnt even recognize what brand it was. Changed it to a walbro and what a difference. No longer knocking at 5k or leaning out at the top.
Had to bring the scaling back up and leaning out past 5.5k and im still at 10.6 afr. I will post my log and fuel map tonight and see what you guys think.
Now i need to turn the boost up some as the map im using is only around 19psi.
Old Apr 15, 2013 | 06:41 PM
  #33
yositoco's Avatar
Attached the log and current fuel map
Attached Thumbnails Newbie needing help with Knock and timing map-fuel-trim-after-walbro.png
File Type: zip
erggy
Jun 3, 2013 09:23 AM
EvoIXPilot
Feb 8, 2013 05:01 AM
90zcrex
Nov 11, 2012 04:40 PM
DarkerStars
May 12, 2012 11:11 PM
EViR
May 22, 2009 11:48 PM
