AFR really rich only when engine is cold
Old Mar 13, 2013 | 08:03 AM
sdanyow's Avatar
What tables need to be adjusted in ecuflash to lean the car out when engine is cold.
(Below 140 degree fahrenheit)
Black smoke (9 AFR) during the first few miles of driving and once the car is warmed up it is fine.
Thanks in advance.
Old Mar 13, 2013 | 05:26 PM
richardjh's Avatar
9:1 AFR? At what throttle level?
Rich
Old Mar 13, 2013 | 06:01 PM
sdanyow's Avatar
Billows black smoke and car sputters with tps less than 30% and little to no boost.
A lot worse when temps outside are below freezing.
Assuming there is some cold table adding fuel somewhere because it is fine after the car warms up a little.
I will try and get a log of this next week if that will help.
Thanks again this has been driving me crazy.
Old Mar 14, 2013 | 02:29 PM
sdanyow's Avatar
Assuming in this cold state (closed loop) all AFR reading are adjusted by the computer from the front O2 sensor.
Could this possibly be a front O2 sensor problem?
Old Sep 2, 2013 | 04:31 AM
GottaZtt's Avatar
did you change injectors, since closed loop is activated by temp in most calibration. you need to adjust your openloop fueling tables.
Old Sep 2, 2013 | 04:51 AM
GottaZtt's Avatar
ETC Fuel Compensation is what you should look into
Old Sep 7, 2013 | 05:33 PM
darkeye's Avatar
Is there a similar table like "ETC Fuel Compensation"?
Couldn't find any table like this in my Tephraxmod 53040110 (53040010) Map. I already have the latest xml from Goldenevo.
I also need to lean out when engine is cold.
Old Sep 9, 2013 | 01:08 AM
GottaZtt's Avatar
post your ROM
Old Sep 10, 2013 | 12:20 AM
GottaZtt's Avatar
<table name="ECT Fuel Compensation #1" address="5ab11" category="Fuel" type="3D" level="2" swapxy="true" scaling="Percent128">
<table name="Load" address="617d6" type="X Axis" elements="41" scaling="Load"/>
<table name="Coolant Temperature" address="6101e" type="Y Axis" elements="9" scaling="Temp"/>
</table>
<table name="ECT Fuel Compensation #2" address="5ac89" category="Fuel" type="3D" level="2" swapxy="true" scaling="Percent128">
</table>
Old Oct 15, 2013 | 04:21 PM
sdanyow's Avatar
GottaZtt, This defiantly sounds like the right table.
It is getting colder now and I just adjusted and lower some cells by 10% - 30%
Made table #1 and #2 the same and will report back.
Thank you.
Old Oct 16, 2013 | 05:06 PM
sdanyow's Avatar
That table took care of the problem
Thanks again.
Old Nov 13, 2013 | 01:35 AM
GottaZtt's Avatar
^great that is working good now
Jovan Caro
Apr 28, 2017 08:42 AM
Nniikkooss
Mar 23, 2017 01:34 AM
AKB_EVO
Mar 19, 2017 10:08 AM
dawidevo
Feb 25, 2014 05:23 PM
