Cannot Disable Rear o2 Sensor EcuFlash 12' Evo X
Old Mar 23, 2013 | 02:46 PM
slostjoe's Avatar
So, I have searched and read all I can to try to perform this and I am having no luck...
I have my wide band tied into the factory rear o2 sensor wire and Evo Scan is reading voltage from my AEM. I disable both the settings in EcuFlash, upload the map and the CEL goes away. After about 2mins of running or and ignition cycle it comes right back on and it throwing o2 sensor codes. This is driving me insane!
Thanks for any help in advance.
Old Mar 23, 2013 | 07:50 PM
BakaUnchi's Avatar
did you turn the REAR o2 off in options ?
Old Mar 23, 2013 | 08:06 PM
slostjoe's Avatar
Am I looking in the wrong place?
Old Mar 23, 2013 | 08:19 PM
BakaUnchi's Avatar
yep
its in the ECU options set #2 map change to 0 from 1
Old Sep 1, 2013 | 04:11 PM
Risky Guy's Avatar
Disabling just causes that cel/ses light to pop on almost instantly.
Unless you have a bad 02, doubtful or massive exhaust leak.
Had exact same issue, try a bung extender/non fouler.
Worked like a champ. It should do the trick.
Good luck with getting it straight, I hate that ses light staring at me.
Old Sep 20, 2013 | 04:11 PM
FastAttack's Avatar
you can disable that CEL/SES light as well
Old Dec 15, 2013 | 06:14 PM
Risky Guy's Avatar
Yes but I don't think you can pass emissions.
I prefer to fix the problem, then do a short cut.
silentsmoker84
Aug 6, 2024 09:54 AM
_RMC_
Apr 11, 2014 12:33 PM
Big Bald
Oct 16, 2013 07:21 PM
dsmmk4
May 22, 2013 06:01 AM
Mauricio Evo IV
Sep 2, 2011 06:49 PM
