WGDC vs Wastegate
Old Mar 31, 2013 | 08:09 PM
AKW89's Avatar
WGDC vs Wastegate
Okay, sorry I don't have my car running to experiment with this otherwise I would try this and figure it out.
Say I have a stock pill in the stock boost solenoid and the stock wastegate so then the WGDC is at 100% so I am running stock boost. Got that!
Now let's say I swap out the turbo and I have a 25psi wastegate connected to the stock plumbing (FP Green w/ 25psi wastegate). So at 100% WGDC would I run 25psi with that wastegate due to it running at 100% or is that somehow limited by the stock plumbing anyways?
Sorry, I am just trying to figure EVERYTHING out before I start.
Old Mar 31, 2013 | 08:15 PM
evo8426's Avatar
You would run an extreme amount of boost until the ECU decides to cut fuel. I do not recommend changing the WGA without adjusting WGDC down to zero and slowing start adding it back in until reaching the desired boost level.
Old Mar 31, 2013 | 08:19 PM
Raptord's Avatar
It's the opposite. With 0% WGDC you would be running off wastegate spring pressure, so 25 psi. With 100% the wastegate will always be closed, so you'll run much more than 25psi.
Old Mar 31, 2013 | 08:43 PM
AKW89's Avatar
Awesome replies. That's not how I figured that working at all. Thank you very very much. So basically I should add the 25 psi wastegate with stock plumbing and then set WGDC to around 1%, log boost, and adjust accordingly.
I really appreciate your fast replies.
03Ev0luti0n
Aug 4, 2015 12:32 PM
black E
Evo X Dyno Results
19
Jan 1, 2015 12:59 PM
robin-evo6rs2
Nov 7, 2013 08:47 AM
CornFedEvo
Dec 4, 2009 09:43 PM
Raceghost
Sep 14, 2009 05:46 AM
