WGDC wont go down.
Old Nov 4, 2013 | 10:10 PM
robin-evo6rs2's Avatar
WGDC wont go down.
Hello,
I got a e5.
now i'm trying to run a 3-poort on the Ceddy rom.
but i cant get the WGDC to go down.
0 out the boost corretion tabel
put say 40% WGDC in the map.
And stil i'm getting only a smal dip in DC
This log was on a stock E5.
Max'd out his 2 bar boost meter.
The WGDC only goes to 87% and goes back up.
Engine load in the map is at 200.
Error is all @ 0
WGDC in the map was very lo...40% i think.... try'd 25% as well.. same thing
Ceddy rom has map switch.. so does the car.
Put in the same.
try'd 2 ecu's
3 rom's
2 3-poorts
WGDC juist wont look at the rom.
the log was with this rom.
File Type: zip
Old Nov 5, 2013 | 09:39 AM
X Double Dot's Avatar
This is what I said....
"I've seen a table in the roms named "WGDC at fault". Check if that is set to 87.5%. I think stock is something like 64%.
Wondering if the ecu is defaulting to that value due to some other issue (loose wire in the harness etc)."
I relooked at the graph you have and saw this is not likely, sorry
Old Nov 5, 2013 | 10:11 AM
That table has not been discovered in the rom yet.
Or i have the wrong xml
Tryd the stock rom and the Ceddy.
Old Nov 5, 2013 | 11:10 AM
ReaperX's Avatar
Have you ruled out the possibility of a mechanical problem? Check the vacuum lines running to the WG and make sure they are in good condition, no holes or rips, and zip tied.
Old Nov 5, 2013 | 11:52 AM
Yeah.
Just done a leak test...
Actuator is brand new.... half a hole preload.
I get a nice 0.8 bar when i disconnect the 3poort but lave it plumd in.
It is a map/ecu thing.
If you look at the log you see 87.5 dutycycle where it should be 40 or something like that
Old Nov 7, 2013 | 08:47 AM
Bump this up.
Still don't know why this happens
PL_MR
Aug 11, 2020 08:14 PM
okevolutionVIII
Jul 29, 2016 01:13 AM
robin-evo6rs2
Feb 21, 2014 03:42 AM
rodrig.diaz3
Jun 28, 2009 01:37 PM
razorlab
Mar 20, 2008 11:28 AM
