Transfer to SD, WGDC lowe than before and target map
Old May 12, 2017 | 12:08 PM
PL_MR's Avatar
Hi,
I'm trying to transfer from direct boost control to SD. It's running well but my max boost (26) is lower of 2 psi.
i check data logging and I see that the WGDC is hitting 5% less.
I try to compare the map definition at a lot of place to see if everything is setup the same for omnibar 4 map, it seem good. I compare the desire boost map and WGDC map and they are the same.
exemple, 5500rpm, should hit wgdc at 83% but i'm only at 78%.
I don't know why it doesn't go to target. When i look at the WGDC correction datalog, it's a 0 everywhere
any idea of what I could check
Does the VE table could affect that?
Old Aug 11, 2020 | 08:14 PM
qwertykerr's Avatar
Originally Posted by PL_MR
Hi,
maybe because yout TPS isn't hitting the 87 so it's interpolating with the previous column?
kons6
May 26, 2016 02:41 AM
mxguy1286
May 18, 2011 07:43 PM
JoeBee
Feb 22, 2007 05:37 AM
bishiboy
13
Mar 1, 2005 08:19 PM
