How do I increase samples/second in EvoScan?
Old Apr 17, 2013 | 02:41 PM
SQ2Evo's Avatar
Right now a full 3rd gear pull at WOT is only giving me about 20 samples to work with. I'd like to significantly increase this but can't find where/how to adjust it in EvoScan. Any suggestions?
Old Apr 17, 2013 | 03:50 PM
90zcrex's Avatar
Make sure you are only logging the things you really need, also in the options unclick the log to screen, That helped me a good bit.
Old Apr 17, 2013 | 05:31 PM
SQ2Evo's Avatar
So will Evoscan just log as much as it possibly can by default? Meaning the rate at which it logs is solely dependent on how much I ask it to record? I figured there might be a setting to change how much the user wants evoscan to log
Old Apr 17, 2013 | 06:36 PM
CDrinkH2O's Avatar
Change the baud rate to 62500 in your ROM and in evoscan. That will increase the sampling to the max. I got roughly 4 times the standard rate of 16250.
How do I increase samples/second in EvoScan?-speed1.png
How do I increase samples/second in EvoScan?-speed2.png
Old Apr 18, 2013 | 05:56 AM
evo8426's Avatar
You cannot increase the baud rate with the Evo 9.
Turn off "Log Data to Screen" this one here will increase your logged data a whole lot.
Only log items such as TPS, RPM, Load, Wideband, Timing, Boost, and KnockSum. Those are really the only essential items.
Old Apr 19, 2013 | 09:09 AM
SQ2Evo's Avatar
Nice, turned off Log to screen and unchecked some unnecessary items and got way better results. Thanks for the help
Lukelis
Apr 26, 2011 05:48 AM
Dochka
Mar 17, 2011 03:46 AM
germanracing
Jan 19, 2011 07:58 AM
2k4EvoVIII
Feb 13, 2009 01:47 AM
