Timing randomization from 2k to 3.5k rpm
Iat correction zeroed out?
8858 is popular I'm guessing because tephra and others are from austrailia. The porting and patchwork was done to well known roms so that's my only thoughts.
If you switch to 8859 there is a lot of advanced development there and if you had a highly modified car I'd switch to that.
My 8858 rom is dead on timing. There's corrections and compensations that need to be accommodated and take some time to iron out. Although more common it's still lesser known.
IAT correction is zeroed until +25C where it is at 1.5.
I've been looking at 8859 and at least the structure of the ROM is grouped better and it is very easy to read compared to what I have now with 8858.
I'm waiting for my tuner to get back to me. One more anomaly with 8858 is that my idle is set to be at 1039rmp with engine at full temp, but my idle logs show the following:
For reference, here is my Target Minimum Idle table.Code:
TPS RPM Tim Load KnockV KS AFR 18.82352941 625 10 28.6 0.0585 0 14.3472 18.82352941 625 10 28.6 0.0585 0 14.3472 18.82352941 625 10 29.9 0.0585 0 14.3472 18.82352941 625 10 29.9 0.078 0 14.3472 18.82352941 625 10 29.9 0.156 0 14.3325 18.82352941 625 10 29.9 0.156 0 14.3325 18.82352941 625 10 29.9 0.039 0 14.3325 18.82352941 625 10 29.9 0.117 0 14.3325 18.82352941 625 10 29.9 0.078 0 14.3325 18.82352941 625 10 29.9 0.078 0 14.3178 18.82352941 625 10 29.9 0.156 0 14.3178 18.82352941 625 10 29.9 0.0585 0 14.3178 18.82352941 625 10 29.9 0.078 0 14.3178 18.82352941 625 10 29.9 0.078 0 14.3178 18.82352941 625 10 29.9 0.078 0 14.3178 18.82352941 625 10 29.9 0.1755 0 14.3178 18.82352941 625 10 29.9 0.0585 0 14.3178 18.82352941 625 10 29.9 0.0585 0 14.3178 18.82352941 625 10 29.9 0.0975 0 14.3178 18.82352941 625 10 29.9 0.0585 0 14.3178 18.82352941 625 10 29.9 0.156 0 14.3178 18.82352941 625 10 29.9 0.156 0 14.3178 18.82352941 625 10 29.9 0.0585 0 14.3178 18.82352941 625 10 29.9 0.078 0 14.3178 18.82352941 625 10 29.9 0.078 0 14.3178 18.82352941 625 10 29.9 0.078 0 14.3178 18.82352941 625 10 29.9 0.0975 0 14.3178 18.82352941 625 10 29.9 0.0585 0 14.3178 18.82352941 625 10 29.9 0.0585 0 14.3178 18.82352941 625 10 29.9 0.0585 0 14.3178 18.82352941 625 10 29.9 0.0195 0 14.3178 18.82352941 625 10 29.9 0.1365 0 14.3178 18.82352941 625 10 29.9 0.1365 0 14.3031 18.82352941 625 10 29.9 0.0975 0 14.3031 18.82352941 625 10 29.9 0.0585 0 14.3031 18.82352941 625 10 29.9 0.039 0 14.3031 18.82352941 625 10 29.9 0.039 0 14.3031 18.82352941 625 10 29.9 0.117 0 14.3031 18.82352941 625 10 29.9 0.039 0 14.3031 18.82352941 625 10 29.9 0.039 0 14.3031 18.82352941 625 10 29.9 0.117 0 14.3031 18.82352941 625 10 29.9 0.078 0 14.3031 18.82352941 625 10 29.9 0.1365 0 14.3031 18.82352941 625 10 29.9 0.1365 0 14.3031 18.82352941 625 10 29.9 0.0585 0 14.3031 18.82352941 625 10 29.9 0.0975 0 14.3031 18.82352941 625 10 28.6 0.0195 0 14.3031 18.82352941 625 10 28.6 0.0195 0 14.3031 18.82352941 656.25 10 28.6 0.195 0 14.3031 18.82352941 656.25 10 28.6 0.039 0 14.3031 18.82352941 625 10 28.6 0.078 0 14.3031 18.82352941 625 10 28.6 0.078 0 14.3031 18.82352941 625 10 28.6 0.0585 0 14.3031 18.82352941 625 10 28.6 0.0975 0 14.3031 18.82352941 656.25 10 28.6 0.0975 0 14.3031 18.82352941 656.25 10 28.6 0.0585 0 14.3031 18.82352941 625 10 28.6 0.0585 0 14.2884 18.82352941 625 10 28.6 0.078 0 14.2884 18.82352941 625 10 28.6 0.078 0 14.2884 18.82352941 625 10 28.6 0.078 0 14.2884 18.82352941 656.25 10 28.6 0.0585 0 14.2884 18.82352941 625 10 28.6 0.078 0 14.2884 18.82352941 625 10 28.6 0.078 0 14.2884 18.82352941 625 10 28.6 0.0585 0 14.2884 18.82352941 625 10 28.6 0.117 0 14.2884 18.82352941 625 10 28.6 0.117 0 14.2884 18.82352941 625 10 29.9 0.0585 0 14.2884 18.82352941 625 10 29.9 0.0975 0 14.2884 18.82352941 625 10 29.9 0.078 0 14.2884 18.82352941 625 10 29.9 0.078 0 14.2884 18.82352941 625 10 29.9 0.078 0 14.2884 18.82352941 625 10 29.9 0.039 0 14.2884 18.82352941 625 10 29.9 0.039 0 14.2884 18.82352941 625 10 29.9 0.039 0 14.2884 18.82352941 625 10 29.9 0.0975 0 14.2884 18.82352941 625 10 29.9 0.117 0 14.2884 18.82352941 625 10 29.9 0.117 0 14.2884 18.82352941 625 10 29.9 0.0585 0 14.2884 18.82352941 625 10 29.9 0.0975 0 14.2884 18.82352941 625 10 29.9 0.078 0 14.2737 18.82352941 625 10 29.9 0.078 0 14.2737 18.82352941 625 10 29.9 0.1755 0 14.2737 18.82352941 625 10 29.9 0.039 0 14.2737 18.82352941 625 10 29.9 0.039 0 14.2737 18.82352941 625 10 29.9 0.0585 0 14.2737 18.82352941 625 10 29.9 0.078 0 14.2737 18.82352941 625 10 29.9 0.1365 0 14.2737 18.82352941 625 10 29.9 0.039 0 14.2737 18.82352941 625 10 29.9 0.039 0 14.2737 18.82352941 625 10 29.9 0.0585 0 14.2737 18.82352941 625 10 29.9 0.039 0 14.2737 18.82352941 625 10 29.9 0.0975 0 14.2737 18.82352941 625 10 29.9 0.0975 0 14.2737 18.82352941 625 10 29.9 0.039 0 14.2737 18.82352941 625 10 29.9 0.0975 0 14.2737 18.82352941 625 10 29.9 0.078 0 14.2737 18.82352941 625 10 29.9 0.078 0 14.2737 18.82352941 625 10 29.9 0.1365 0 14.2443 18.82352941 625 10 29.9 0.078 0 14.2443 18.82352941 625 10 29.9 0.078 0 14.2443 18.82352941 625 10 29.9 0.078 0 14.2443 18.82352941 625 10 29.9 0.039 0 14.2443 18.82352941 625 10 29.9 0.1365 0 14.2443 18.82352941 625 10 29.9 0.0585 0 14.2443 18.82352941 625 10 29.9 0.0585 0 14.2443 18.82352941 625 10 29.9 0.078 0 14.2443 18.82352941 625 10 29.9 0.078 0 14.259 18.82352941 625 10 29.9 0.117 0 14.259 18.82352941 625 10 29.9 0.117 0 14.259 18.82352941 625 10 29.9 0.0585 0 14.259 18.82352941 625 10 29.9 0.0585 0 14.259 18.82352941 625 10 29.9 0.0585 0 14.259 18.82352941 625 10 29.9 0.0585 0 14.259 18.82352941 625 10 29.9 0.1755 0 14.259 18.82352941 625 10 29.9 0.039 0 14.259 18.82352941 625 10 29.9 0.078 0 14.2737 18.82352941 625 10 29.9 0.078 0 14.2737 18.82352941 625 10 29.9 0.0975 0 14.2737 18.82352941 625 10 29.9 0.078 0 14.2737 18.82352941 625 10 29.9 0.039 0 14.2737 18.82352941 625 10 29.9 0.039 0 14.3031 18.82352941 625 10 29.9 0.078 0 14.3031 18.82352941 625 10 29.9 0.039 0 14.3031 18.82352941 625 10 29.9 0.1365 0 14.3031 18.82352941 625 10 29.9 0.1365 0 14.3178 18.82352941 625 10 29.9 0.039 0 14.3178 18.82352941 625 10 29.9 0.039 0 14.3178 18.82352941 625 10 29.9 0.039 0 14.3178 18.82352941 625 10 29.9 0.039 0 14.3178 18.82352941 625 10 29.9 0.1365 0 14.3178 18.82352941 625 10 29.9 0.039 0 14.3178 18.82352941 625 10 29.9 0.039 0 14.3178 18.82352941 625 10 29.9 0.078 0 14.3178 18.82352941 625 10 29.9 0.039 0 14.3178 18.82352941 625 10 29.9 0.195 0 14.3178 18.82352941 625 10 29.9 0.195 0 14.3178 18.82352941 625 10 29.9 0.039 0 14.3178 18.82352941 625 10 29.9 0.0975 0 14.3178 18.82352941 625 10 29.9 0.078 0 14.3325 18.82352941 625 10 29.9 0.078 0 14.3325 18.82352941 625 10 29.9 0.1755 0 14.3325 18.82352941 625 10 29.9 0.039 0 14.3325 18.82352941 625 10 29.9 0.039 0 14.3325 18.82352941 625 10 29.9 0.078 0 14.3619 18.82352941 625 10 29.9 0.0585 0 14.3619 18.82352941 625 10 29.9 0.0585 0 14.3619 18.82352941 625 10 29.9 0.1755 0 14.3619 18.82352941 625 10 29.9 0.0195 0 14.3619 18.82352941 625 10 29.9 0.0585 0 14.3619 18.82352941 625 10 29.9 0.0585 0 14.3619 18.82352941 625 10 29.9 0.0585 0 14.3619 18.82352941 625 10 29.9 0.0975 0 14.3619 18.82352941 625 10 29.9 0.0975 0 14.3619 18.82352941 625 10 29.9 0.0975 0 14.3619 18.82352941 625 10 29.9 0.0585 0 14.3619 18.82352941 625 10 29.9 0.0585 0 14.3619 18.82352941 625 10 29.9 0.039 0 14.3619 18.82352941 625 10 29.9 0.078 0 14.3619 18.82352941 625 10 29.9 0.078 0 14.3619 18.82352941 625 10 29.9 0.0585 0 14.3619 18.82352941 593.75 10 29.9 0.039 0 14.3619 18.82352941 593.75 10 29.9 0.039 0 14.3619 18.82352941 593.75 10 29.9 0.078 0 14.3619 18.82352941 593.75 10 29.9 0.0975 0 14.3619 18.82352941 625 10 29.9 0.039 0 14.3619 18.82352941 625 10 29.9 0.1365 0 14.3619 18.82352941 625 10 29.9 0.1365 0 14.3619 18.82352941 625 10 29.9 0.0975 0 14.3766 18.82352941 625 10 29.9 0.117 0 14.3766 18.82352941 625 10 29.9 0.117 0 14.3766 18.82352941 625 10 29.9 0.0585 0 14.3766 18.82352941 625 10 29.9 0.078 0 14.3766 18.82352941 625 10 29.9 0.078 0 14.3913 18.82352941 593.75 10 29.9 0.078 0 14.3913 18.82352941 593.75 10 29.9 0.0975 0 14.3913 18.82352941 625 10 29.9 0.0975 0 14.3913 18.82352941 625 10 29.9 0.078 0 14.406 18.82352941 593.75 10 31.2 0.0975 0 14.406 18.82352941 593.75 10 31.2 0.078 0 14.406 18.82352941 625 10 31.2 0.078 0 14.406 18.82352941 625 10 31.2 0.117 0 14.406 18.82352941 625 10 31.2 0.078 0 14.406 18.82352941 625 10 31.2 0.078 0 14.406 18.82352941 625 10 31.2 0.0585 0 14.406 18.82352941 625 10 31.2 0.078 0 14.406 18.82352941 625 10 31.2 0.0975 0 14.406 18.82352941 625 10 31.2 0.0975 0 14.4354 18.82352941 625 10 31.2 0.039 0 14.4354 18.82352941 625 10 29.9 0.0975 0 14.4354 18.82352941 625 10 29.9 0.0975 0 14.4354 18.82352941 625 10 29.9 0.0585 0 14.4354 18.82352941 625 10 29.9 0.156 0 14.4354 18.82352941 625 10 29.9 0.0585 0 14.4354 18.82352941 625 10 29.9 0.0585 0 14.4354 18.82352941 625 10 29.9 0.0975 0 14.4354 18.82352941 625 10 29.9 0.0585 0 14.4501 18.82352941 625 10 29.9 0.0585 0 14.4501 18.82352941 625 10 29.9 0.1365 0 14.4501 18.82352941 625 10 29.9 0.039 0 14.4501 18.82352941 625 10 29.9 0.039 0 14.4501 18.82352941 625 10 29.9 0.1365 0 14.4501 18.82352941 625 10 29.9 0.078 0 14.4501 18.82352941 625 10 29.9 0.078 0 14.4501 18.82352941 625 10 29.9 0.078 0 14.4501 18.82352941 625 10 29.9 0.0585 0 14.4501 18.82352941 625 10 29.9 0.078 0 14.4795 18.82352941 593.75 10 29.9 0.078 0 14.4795 18.82352941 593.75 10 29.9 0.0585 0 14.4795 18.82352941 593.75 10 29.9 0.1365 0 14.4795 18.82352941 625 10 29.9 0.0585 0 14.4795 18.82352941 625 10 29.9 0.0585 0 14.4795 18.82352941 625 10 29.9 0.0585 0 14.4795 18.82352941 625 10 29.9 0.0585 0 14.4795 18.82352941 625 10 29.9 0.1365 0 14.4795 18.82352941 625 10 29.9 0.1365 0 14.4942 18.82352941 625 10 29.9 0.0585 0 14.4942 18.82352941 625 10 29.9 0.039 0 14.4942 18.82352941 625 10 29.9 0.039 0 14.4942 18.82352941 625 10 29.9 0.0585 0 14.4942 18.82352941 625 10 29.9 0.117 0 14.5089 18.82352941 625 10 29.9 0.0585 0 14.5089 18.82352941 625 10 29.9 0.0585 0 14.5089 18.82352941 656.25 10 29.9 0.0585 0 14.5089 18.82352941 656.25 10 29.9 0.0195 0 14.553 18.82352941 656.25 10 29.9 0.1365 0 14.553 18.82352941 656.25 10 29.9 0.0585 0 14.553 18.82352941 656.25 10 29.9 0.0585 0 14.553 18.82352941 656.25 10 29.9 0.039 0 14.553 18.82352941 656.25 10 28.6 0.0195 0 14.5971 18.82352941 656.25 10 28.6 0.156 0 14.5971 18.82352941 656.25 10 28.6 0.156 0 14.5971 18.82352941 656.25 10 28.6 0.0585 0 14.5971 18.82352941 656.25 10 28.6 0.039 0 14.5971 18.82352941 656.25 10 28.6 0.039 0 14.5971 18.82352941 656.25 10 28.6 0.039 0 14.5971 18.82352941 656.25 10 28.6 0.1755 0 14.5971 18.82352941 656.25 10 28.6 0.039 0 14.5971 18.82352941 656.25 10 28.6 0.039 0 14.5971 18.82352941 656.25 10 28.6 0.078 0 14.5824 18.82352941 625 10 28.6 0.039 0 14.5824 18.82352941 656.25 10 28.6 0.0975 0 14.5824 18.82352941 656.25 10 28.6 0.0975 0 14.5824 18.82352941 656.25 10 28.6 0.039 0 14.5824 18.82352941 656.25 10 28.6 0.0975 0 14.5677 18.82352941 656.25 10 28.6 0.0975 0 14.5677 18.82352941 656.25 10 28.6 0.0585 0 14.5677 18.82352941 656.25 10 28.6 0.156 0 14.5677 18.82352941 656.25 10 28.6 0.156 0 14.5677 18.82352941 656.25 10 28.6 0.0585 0 14.5383 18.82352941 656.25 10 28.6 0.0585 0 14.5383 18.82352941 625 10 28.6 0.0195 0 14.5383 18.82352941 625 10 28.6 0.0195 0 14.5383 18.82352941 656.25 10 28.6 0.117 0 14.5383 18.82352941 656.25 10 28.6 0.0585 0 14.5236 18.82352941 625 10 28.6 0.0585 0 14.5236 18.82352941 625 10 28.6 0.078 0 14.5236 18.82352941 625 10 28.6 0.0585 0 14.5236 18.82352941 625 10 28.6 0.156 0 14.5089 18.82352941 656.25 10 28.6 0.156 0 14.5089 18.82352941 656.25 10 28.6 0.039 0 14.5089 18.82352941 625 10 28.6 0.039 0 14.5089 18.82352941 625 10 28.6 0.078 0 14.5089 18.82352941 625 10 28.6 0.078 0 14.5089 18.82352941 625 10 28.6 0.117 0 14.5089 18.82352941 625 10 29.9 0.0585 0 14.5089 18.82352941 625 10 29.9 0.078 0 14.5089 18.82352941 625 10 29.9 0.078 0 14.5089 18.82352941 593.75 10 29.9 0.078 0 14.4795 18.82352941 593.75 10 29.9 0.117 0 14.4795 18.82352941 625 10 29.9 0.117 0 14.4795 18.82352941 625 10 29.9 0.039 0 14.4795 18.82352941 593.75 10 29.9 0.0585 0 14.4795 18.82352941 593.75 10 29.9 0.0585 0 14.4795 18.82352941 593.75 10 29.9 0.039 0 14.4795 18.82352941 593.75 10 29.9 0.156 0 14.4795 18.82352941 593.75 10 29.9 0.156 0 14.4795 18.82352941 593.75 10 31.2 0.0975 0 14.4648 18.82352941 593.75 10 29.9 0.039 0 14.4648 18.82352941 593.75 10 29.9 0.078 0 14.4648 18.82352941 593.75 10 29.9 0.078 0 14.4648 18.82352941 593.75 10 29.9 0.1365 0 14.4648 18.82352941 625 10 29.9 0.0585 0 14.4501 18.82352941 625 10 29.9 0.0975 0 14.4501 18.82352941 625 10 29.9 0.0975 0 14.4501 18.82352941 625 10 29.9 0.039 0 14.4501 18.82352941 625 10 29.9 0.156 0 14.4501 18.82352941 656.25 10 29.9 0.0585 0 14.4501 18.82352941 656.25 10 29.9 0.039 0 14.4501 18.82352941 656.25 10 29.9 0.039 0 14.4501 18.82352941 656.25 10 29.9 0.078 0 14.4648 18.82352941 656.25 10 29.9 0.117 0 14.4648 18.82352941 656.25 10 29.9 0.0585 0 14.4648 18.82352941 656.25 10 29.9 0.078 0 14.4648 18.82352941 656.25 10 29.9 0.078 0 14.4648 18.82352941 656.25 10 28.6 0.0585 0 14.4942 18.82352941 656.25 10 28.6 0.1365 0 14.4942 18.82352941 656.25 10 28.6 0.039 0 14.4942 18.82352941 656.25 10 28.6 0.039 0 14.4942 18.82352941 656.25 10 28.6 0.078 0 14.4942 18.82352941 656.25 10 28.6 0.0585 0 14.5089 18.82352941 656.25 10 28.6 0.1365 0 14.5089 18.82352941 656.25 10 28.6 0.0585 0 14.5089 18.82352941 656.25 10 28.6 0.0585 0 14.5089 18.82352941 656.25 10 28.6 0.0975 0 14.5089 18.82352941 656.25 10 28.6 0.0585 0 14.5089 18.82352941 656.25 10 28.6 0.1755 0 14.5089 18.82352941 656.25 10 28.6 0.1755 0 14.5089 18.82352941 656.25 10 28.6 0.039 0 14.5089 18.82352941 625 10 28.6 0.0585 0 14.5236 18.82352941 625 10 28.6 0.0585 0 14.5236 18.82352941 625 10 28.6 0.0585 0 14.5236 18.82352941 625 10 29.9 0.1365 0 14.5236 18.82352941 625 10 29.9 0.039 0 14.5236 18.82352941 625 10 29.9 0.117 0 14.5236 18.82352941 625 10 29.9 0.117 0 14.5236 18.82352941 625 10 29.9 0.0585 0 14.5236 18.82352941 625 10 29.9 0.195 0 14.5236 18.82352941 625 10 29.9 0.039 0 14.5383 18.82352941 625 10 29.9 0.039 0 14.5383 18.82352941 625 10 29.9 0.0585 0 14.5383 18.82352941 625 10 29.9 0.039 0 14.5383 18.82352941 625 10 29.9 0.039 0 14.5383 18.82352941 625 10 29.9 0.195 0 14.5383 18.82352941 625 10 29.9 0.0585 0 14.5383 18.82352941 625 10 29.9 0.0975 0 14.5383 18.82352941 625 10 29.9 0.0975 0 14.5383 18.82352941 625 10 29.9 0.078 0 14.5236 18.82352941 625 10 29.9 0.117 0 14.5236 18.82352941 625 10 29.9 0.117 0 14.5236 18.82352941 625 10 29.9 0.0585 0 14.5236 18.82352941 625 10 29.9 0.0585 0 14.5236 18.82352941 625 10 29.9 0.039 0 14.4795 18.82352941 625 10 29.9 0.039 0 14.4795 18.82352941 625 10 29.9 0.1365 0 14.4795 18.82352941 625 10 29.9 0.0975 0 14.4795 18.82352941 593.75 10 29.9 0.0975 0 14.4795 18.82352941 593.75 10 29.9 0.039 0 14.4207 18.82352941 593.75 10 29.9 0.0195 0 14.4207 18.82352941 593.75 10 31.2 0.0975 0 14.4207 18.82352941 593.75 10 31.2 0.0975 0 14.4207 18.82352941 593.75 10 31.2 0.0975 0 14.4207 18.82352941 593.75 10 31.2 0.0585 0 14.4207 18.82352941 593.75 10 31.2 0.0585 0 14.4207 18.82352941 593.75 10 31.2 0.078 0 14.4207 18.82352941 593.75 10 31.2 0.117 0 14.4207 18.82352941 625 10 31.2 0.117 0 14.406 18.82352941 625 10 29.9 0.0585 0 14.406 18.82352941 593.75 10 31.2 0.0585 0 14.406 18.82352941 625 10 29.9 0.078 0 14.406 18.82352941 625 10 29.9 0.078 0 14.406 18.82352941 625 10 29.9 0.0975 0 14.4207 18.82352941 625 10 29.9 0.0585 0 14.4207 18.82352941 625 10 29.9 0.0975 0 14.4207 18.82352941 625 10 29.9 0.0975 0 14.4207 18.82352941 625 10 29.9 0.0585 0 14.4207 18.82352941 625 10 29.9 0.078 0 14.4207 18.82352941 656.25 10 29.9 0.0585 0 14.4207 18.82352941 656.25 10 29.9 0.117 0 14.4207 18.82352941 656.25 10 29.9 0.117 0 14.4207 18.82352941 656.25 10 29.9 0.0585 0 14.406 18.82352941 656.25 10 29.9 0.1365 0 14.406 18.82352941 656.25 10 29.9 0.0195 0 14.406 18.82352941 656.25 10 28.6 0.0975 0 14.406 18.82352941 656.25 10 28.6 0.039 0 14.406 18.82352941 656.25 10 28.6 0.039 0 14.406 18.82352941 656.25 10 28.6 0.1365 0 14.406 18.82352941 656.25 10 28.6 0.0585 0 14.406 18.82352941 656.25 10 28.6 0.0975 0 14.406 18.82352941 656.25 10 28.6 0.0975 0 14.406 18.82352941 656.25 10 28.6 0.0195 0 14.406 18.82352941 656.25 10 28.6 0.1365 0 14.406 18.82352941 656.25 10 28.6 0.0585 0 14.406 18.82352941 656.25 10 28.6 0.078 0 14.4207 18.82352941 625 10 28.6 0.078 0 14.4207 18.82352941 625 10 28.6 0.078 0 14.4207 18.82352941 625 10 29.9 0.156 0 14.4207 18.82352941 625 10 29.9 0.0585 0 14.4207 18.82352941 625 10 29.9 0.0585 0 14.4354 18.82352941 625 10 29.9 0.0975 0 14.4354 18.82352941 625 10 28.6 0.039 0 14.4354 18.82352941 625 10 29.9 0.156 0 14.4354 18.82352941 625 10 29.9 0.156 0 14.4501 18.82352941 625 10 29.9 0.039 0 14.4501 18.82352941 625 10 29.9 0.117 0 14.4501 18.82352941 625 10 29.9 0.0585 0 14.4501 18.82352941 625 10 29.9 0.0585 0 14.4501 18.82352941 625 10 29.9 0.117 0 14.4501 18.82352941 625 10 29.9 0.078 0 14.4501 18.82352941 625 10 29.9 0.078 0 14.4501 18.82352941 625 10 29.9 0.078 0 14.4501 18.82352941 625 10 29.9 0.039 0 14.4354 18.82352941 625 10 29.9 0.117 0 14.4354 18.82352941 625 10 31.2 0.078 0 14.4354 18.82352941 593.75 10 31.2 0.078 0 14.4354 18.82352941 593.75 10 31.2 0.039 0 14.4501 18.82352941 593.75 10 31.2 0.0585 0 14.4501 18.82352941 593.75 10 31.2 0.0585 0 14.4501 18.82352941 593.75 10 31.2 0.117 0 14.4501 18.82352941 625 10 29.9 0.0585 0 14.4501 18.82352941 625 10 31.2 0.0585 0 14.4795 18.82352941 625 10 31.2 0.0585 0 14.4795 18.82352941 625 10 29.9 0.0975 0 14.4795 18.82352941 625 10 29.9 0.117 0 14.4795 18.82352941 625 10 29.9 0.078 0 14.4795 18.82352941 625 10 29.9 0.078 0 14.4795 18.82352941 625 10 29.9 0.0585 0 14.4795 18.82352941 625 10 29.9 0.0585 0 14.4795 18.82352941 625 10 29.9 0.156 0 14.4795 18.82352941 625 10 29.9 0.156 0 14.5089 18.82352941 625 10 29.9 0.0585 0 14.5089 18.82352941 656.25 10 29.9 0.039 0 14.5089 18.82352941 656.25 10 29.9 0.0195 0 14.5089 18.82352941 656.25 10 29.9 0.0195 0 14.5089 18.82352941 656.25 10 29.9 0.156 0 14.5089 18.82352941 656.25 10 29.9 0.039 0 14.5089 18.82352941 656.25 10 29.9 0.039 0 14.5089 18.82352941 656.25 10 29.9 0.039 0 14.5089 18.82352941 656.25 10 29.9 0.078 0 14.4795 18.82352941 656.25 10 29.9 0.0975 0 14.4795 18.82352941 656.25 10 29.9 0.0585 0 14.4795 18.82352941 656.25 10 29.9 0.0585 0 14.4795 18.82352941 656.25 10 29.9 0.078 0 14.4795 18.82352941 656.25 10 29.9 0.0195 0 14.4648 18.82352941 656.25 10 28.6 0.1365 0 14.4648 18.82352941 656.25 10 28.6 0.078 0 14.4648 18.82352941 656.25 10 28.6 0.078 0 14.4648 18.82352941 656.25 10 28.6 0.039 0 14.4648 18.82352941 656.25 10 28.6 0.0585 0 14.4354 18.82352941 656.25 10 28.6 0.117 0 14.4354 18.82352941 656.25 10 28.6 0.078 0 14.4354 18.82352941 656.25 10 28.6 0.078 0 14.4354 18.82352941 656.25 10 28.6 0.039 0 14.4207 18.82352941 656.25 10 28.6 0.0585 0 14.4207 18.82352941 656.25 10 28.6 0.1755 0 14.4207 18.82352941 656.25 10 28.6 0.1755 0 14.4207 18.82352941 656.25 10 28.6 0.039 0 14.4207 18.82352941 656.25 10 28.6 0.0585 0 14.4501 18.82352941 656.25 10 28.6 0.0585 0 14.4501 18.82352941 656.25 10 28.6 0.039 0 14.4501 18.82352941 625 10 28.6 0.156 0 14.4501 18.82352941 656.25 10 28.6 0.078 0 14.4501 18.82352941 625 10 28.6 0.078 0 14.4501 18.82352941 625 10 29.9 0.0585 0 14.4501 18.82352941 625 10 29.9 0.0195 0 14.4501 18.82352941 625 10 29.9 0.0195 0 14.4501
I think your tips is too high. Needs to be in idle mode <16.8 or something like that. You should see timing all over the place at idle
Your base idle need to be set and tps sensor adjusted
Is the tps sensor adjustable with software or a wrench?Also, can you elaborate more about "I'm talking iat vs timing trim."? I'm quite new at this.
Resurrecting this.
I'm now in process of transferring all of my adjustments from 8858 to a 8859 and noticed that where 8858 has Load as "%", 8859 has Load as "kpa". My car is EDM and doesn't have a MAP sensor at all, am I even able to run 8859 if it assumes, for load calculations, that MAP information is available unless I install one and wire it to the ECU?
And if you could lead a blind man for few more steps, what features exactly do I have to disable from 8859 in order to make it work?
I got the ALS to pop up in Ecuflash after getting the 211ratsbuds updated definitions and adding to the XML from this post. After changing all of the values to something that should prevent ALS from kicking up I'm going to give this a go first instead of updating to 8859 that doesn't have ALS functions at all.
If someone knows the periphery bit that would disable ALS I'm all ears
Funnily enough, as stated earlier in this thread, FAA bit.10 fixed this issue, but introduced a notchy cruise as well as blackened spark plugs so that is not a 100% fix for this. Unless I need to modify something else with the bit.10?
You're asking me tho dig deep in the memory bank. I know what is covered to run ,8858 on a usdm in my als thread. It for sure has been covered, just make a quick and dirty Rom flash adnd start and post up the cel you get.
Don't worry about the map sensor that can all be disabled as a 4.bar is not a requirement for v7. I'll help where I can in diagnosis .
Otherwise just setting the sas settings to unobtainable limits or zeroing should work fine.
Keep us posted
Keep us posted
Hey bud, thanks for the assistance. I'm on a trip away from the car until next week, so this will take awhile until I can test it out. I have already modified the rom to make the ALS settings to be unobtainable and will do first logs with that. I also transferred everything that I could from my 8858 to 8859 and will go to that route if this one fails.
I'd love to be able to use 8858 though since this is the only bug that I'm trying to iron out.
8858 ran better on my usdm because less stuff I think so I bet 8857 will be even better for those who care.
I am also doing trials with 89980000, which is a Ralliart version, but similar code.
Possibly even more stripped back I think from what I have seen so far.
This was actually my preferred ROM for this project and I my well go back to it.
It certainly drives nicely, with the best throttle on/off transitions of any evo ECU I have been in, and did not throw any DTC when dropped in my car.
I have been using v5 8858 for my dual map tunes, and managed to provoke the engine into using one of the extremly weird spark maps the other day (the one thats mostly zero with a section of +30 or so). The engine was trying to recover to idle at 500rpm and 30* advance.
No, it did not like it. This table is absent from 8998, which encouraged me to do further testing with it.
