CEL after ecu swap
Old Jun 10, 2013 | 07:20 PM
MadMitsi's Avatar
CEL after ecu swap
recently installed my evo 7 ecu/afm/injectors into my evo 4 and swapped most of the pins needed but yet the check engine light is still on? when evo 4 ecu/injectors/afm were in the light wasn't on. what do i look for?
the pins I changed were: cable 20 moved into 32 pinslot and 21 into 34 pin-slot. also disconnected pin 40.
first start car from cold, then about 10-15 seconds check engine light comes on and stays on.
Old Jun 11, 2013 | 01:06 AM
foxbat's Avatar
That's probably the EGR fault code, since 4's don't have EGR, you need to disable that in the rom.
Old Jun 11, 2013 | 09:43 AM
MechTech's Avatar
First step is see what the code(s) are.
Old Jun 12, 2013 | 02:14 PM
todd6027's Avatar
swap pins 6 and 53
disconnect pin 87
add wire and pin to 79 to allow you to flash the ecu
put 16d0 in periphery 1 turns off o2 heater cel ( evo4 has 2 wire sensor only )
put 8889 in periphery 2 ( disables egr and associated others you dont need )
Old Jun 17, 2013 | 09:05 PM
MadMitsi's Avatar
Cool thanks swapped a few more pins and it improved the idle (was kinda missing a bit on idle) and am going to plug ecu in next week
is removing pin 87 really necessary?
Old Jun 18, 2013 | 06:57 AM
todd6027's Avatar
yes ,its idle switch on 4/5/6 but acd input on 7/8 as idle switch was discontinued
Old Jun 18, 2013 | 07:26 PM
MadMitsi's Avatar
Cool done that now as well, I've also disconnected pin 40, does this have to be grounded or can i just leave it unplugged?
Old Jun 19, 2013 | 05:18 AM
todd6027's Avatar
i just leave it in place
Old Jun 19, 2013 | 07:21 PM
MadMitsi's Avatar
I done everything now and put 16d0 in periphery 1 and put 8889 in periphery 2 and still getting CEL..
Old Jun 21, 2013 | 06:54 AM
todd6027's Avatar
what s the fault code ???
Old Jul 7, 2013 | 02:57 PM
MadMitsi's Avatar
How do i bring up fault codes? Also have noticed my idle on cold start idle creeps upto 1,900 revs, what could this be? -_-
Old Jul 7, 2013 | 04:32 PM
philr8's Avatar
Bridge pins 1 and 4 on the obd socket
Old Jul 7, 2013 | 11:30 PM
MadMitsi's Avatar
cool cheers will try that to see if fault codes come up. do i just watch check engine light and count flashes?
Old Jul 7, 2013 | 11:57 PM
philr8's Avatar
Yes the long pulse is 10 and short is 1
Ie 2 long pulse and 3 short pulse is 23
Old Jul 8, 2013 | 04:24 PM
MadMitsi's Avatar
Hey i tried to get fault codes to come up for CEL but none come up? Although abs light constant flash when 1-4 are bridged. Confused now lol
