Nlts rpm drop
Old Sep 1, 2013 | 11:53 AM
Gordian79's Avatar
Nlts rpm drop
What rpm does nlts use to subtract rpm drop from the main rev limiter or the stationary rev limited?reason I want to know is that I want to test at a lower rpm
Old Sep 1, 2013 | 12:09 PM
90zcrex's Avatar
If you are over the engagement load and speed then NLTS will drop the rpm wherever you push in the clutch. So whether your at 4k or 8k rpm and you push in the clutch it will drop the amount you put into rpm drop.
You can test it by setting load and speed to 0 and just rev the engine and push in the clutch and make sure the rpm drops.
Old Sep 1, 2013 | 03:03 PM
211Ratsbud's Avatar
Right on does not work like the subie nlts. I drop 650 rpm on an evo ix 5 speed (rs)
You can test it at any rpm, like wot @ 2500-3000 and over 110 load is easy to test
Old Sep 1, 2013 | 04:54 PM
Gordian79's Avatar
So with load and speed set to 0 with an rpm drop at 800.lets say I rev steady to 2000 rpm and push the clutch in it should drop to 1200rpm in theory
Old Sep 1, 2013 | 05:01 PM
RaceSolutions's Avatar
Thats it.
And this way you will also see if your clutch switch does troubles.
Had 1 switch on EVO IX death...and was searching 2 days why NLS didnt work properly
Old Sep 1, 2013 | 05:04 PM
90zcrex's Avatar
You got it.
Old Sep 1, 2013 | 05:19 PM
Gordian79's Avatar
You got it.
forgot to ask tps at 20% or something low correct?
Old Sep 1, 2013 | 05:25 PM
Raptord's Avatar
Yes, for the "garage test" you'll want low tps. Basically just enough to get you to free-rev to 3k or something like that.
Old Sep 1, 2013 | 05:49 PM
Gordian79's Avatar
Not working maybe switch is bad or i copied wrong onto my rom mettadata file.If the mod is copied properly it wont be grayed out in ecuflash correct?
Old Sep 1, 2013 | 07:51 PM
Raptord's Avatar
What rom version? You shouldn't have to copy anything, the xml info is already in the v7 xml.
Old Sep 1, 2013 | 09:22 PM
Gordian79's Avatar
Originally Posted by raptord
what rom version? You shouldn't have to copy anything, the xml info is already in the v7 xml.
v5
Old Sep 1, 2013 | 09:29 PM
Raptord's Avatar
Any reason in particular for not using v7? What car is this for?
Old Sep 1, 2013 | 11:35 PM
Gordian79's Avatar
That's what tuner used.03 evo
Old Sep 14, 2016 | 02:20 AM
maxspeed96ct's Avatar
Hey guys I figured I'd bump this old thread vs making a new one.
I just enabled my nlts and set the rpm drop to 1200 to start with.
I feel like I could go much lower, what do most set the rpm drop to on a 5spd ?
My previous vehicle had a n2mb nlts box so it was set off a timer instead of rpm.
Dakota Evo
Mar 26, 2017 11:36 PM
Dmx3alo
Jan 20, 2017 02:28 PM
maxspeed96ct
Sep 4, 2016 05:50 AM
tephra
Aug 19, 2016 10:07 AM
rodrig.diaz3
AEM EMS
34
Jul 1, 2016 10:19 AM
