Weird acceleration problem
Old Jan 20, 2017 | 08:36 AM
Dmx3alo's Avatar
Weird acceleration problem SOLVED
When I'm shifting from second gear to third gear the car accelerates then stops as if I'm not pressing the accelerator pedal for 3 seconds then accelerates again even tho my foot is to the floor. I own a 2006 Evo 9 MR. I hope someone can explain this. Thank you alot
So I actually had the tephramod NLTS (no lift to shift) I tried it out by getting the engine to 3k rpm at 3rd gear and then going full throttle and pressing the clutch all the way while still holding the throttle wide open the rpm dripped by 500 and kept bouncing while I can easily shift gears
Old Jan 20, 2017 | 09:56 AM
barneyb's Avatar
When this occurs (no acceleration) does the tach show an increase in rpm?
Old Jan 20, 2017 | 10:18 AM
Dmx3alo's Avatar
No, it doesn't Rev up it either stays or drops slowly but then it gets on accelerating again
Old Jan 20, 2017 | 01:43 PM
ReaperX's Avatar
Has the car been tuned using tephramod and has no lift to shift activated?
Old Jan 20, 2017 | 02:28 PM
Dmx3alo's Avatar
i just bought the car three days ago, how can i find out if it has it?
DJ Jazzy Death
Lancer Troubleshooting
12
Jan 19, 2011 07:53 AM
JKD
Aug 29, 2009 05:20 PM
g0pher
Aug 26, 2009 05:08 PM
