Tuning Evo789 ACD
Old Jan 23, 2014 | 04:20 PM
  #121
merlin.oz's Avatar
Post #111 Tuning Notes has been up-dated, again.
Old Jan 23, 2014 | 04:30 PM
  #122
ROB-80E's Avatar
Wow, she starts to blow my mind when you start adding in the D E and F tables! lol
Hey Dave, have you managed to isolate or do you think that triplicates of those D E and F tables align to a Tarmac Gravel and Snow setting?
Old Jan 23, 2014 | 06:39 PM
  #123
merlin.oz's Avatar
D-Tables, Speed Delta (+/-) Correction, 3 tables TGC as usual.
E-Tables, Speed Delta (+/-) Lockup Adder, 6 tables, TGC Accel and TGC Decel as usual
F-Tables, Speed Delta (+) Lockup Adder, 3 tables only TGC as usual.
Its seems to look complicated, but when you start to follow the calculation trail, it makes sense, or it does at the moment.
There seem to be time constant filters applied to most if not all steps in the calculation to provide suitable attack and decay ramps and at the end some sort of scaling factor and of course upper and lower limits. And overflow checks which I guess are like internal limits. And test/branch conditions for unknown purposes.
My time on this is drawing to a close, only a few days left before I will be otherwise occupied.
Old Jan 23, 2014 | 07:49 PM
  #124
Raptord's Avatar
This is making my brain hurt.
Practical example I'd like to understand: At a track I frequently go to, there's a medium-sized 3rd gear sweeper. Unless I run higher pressures in the rear tires than the fronts, I struggle to get back on the throttle as early as I'd like because the front just pushes. In this situation, would I want the ACD to lock more or less, in order to minimize the push?
Old Jan 23, 2014 | 08:13 PM
  #125
merlin.oz's Avatar
less
Old Jan 24, 2014 | 04:27 AM
  #126
charlie.tunah's Avatar
wow. Thats definitely backwards than what I thought it would be.
If the front tires are currently pushing, wouldnt less lock make them spin more? Ive got in my head that with less lockup, tq will be transferred to the end with the least grip. (thinking like an open diff in a rear end)
Or are you saying that the front tires are loosing traction BECAUSE they are receiving too much tq from the lockup?
Old Jan 24, 2014 | 02:29 PM
  #127
merlin.oz's Avatar
New xmls added to the first post, these have all the latest revisions to descriptions, scaling and additional tables and parameters, including the known Time Constants (there are more to be decoded).
Deffinitions include:
401403
401404
401702
Old Jan 25, 2014 | 04:05 AM
  #128
Floppyz's Avatar
Wonderfull, incredible work Merlin! Thank you very much for do this for all of us ...11
Now seems to be more logical behaviour, I'd like to have a race ciurcuit to test all of those maps
Did you insert current limits too?
Old Jan 25, 2014 | 05:49 AM
  #129
deeman101's Avatar
In a very loose sense, if your car is pushing and you lock the ACD you're going to make it act more like a fwd instead of giving it the chance to act rwd.
A tuner I know who tunes STi DCCDs basically said the object is to have the c.diff as open as possible, but start applying lock if theres wheel slip. Basically use the lockup for traction.
Old Jan 25, 2014 | 01:40 PM
  #130
merlin.oz's Avatar
^ what deeman says is pretty much right.
Old Jan 26, 2014 | 02:09 AM
  #131
thank you guys very much for the explanation.
Old Jan 26, 2014 | 02:12 AM
  #132
el.guerrero's Avatar
Ignored ahahahahhahaha ohhh filippo!
Old Jan 26, 2014 | 03:15 AM
  #133
merlin.oz's Avatar
Current limits? I missed that query, no, not found yet.
I suspect we will find that an ACD Lockup adder total of 255 (or possibly 250) will equal maximum possible current.
The Ralliart K2 gravel rally rom has values that can hit 255 and I think it is a 1-byte parameter so 255 will be the limit. Not quite there yet though.
Has anyone measured the resistance of the proportioning valves?
May have found the 5kph hand brake on = ACD open speed setting.
Old Jan 26, 2014 | 03:19 AM
  #134
donner's Avatar
I believe I just found it, it might be inbuilt on possible duty cycle control table @128D8.
Old Jan 26, 2014 | 09:17 AM
  #135
Malocas's Avatar
The progress looks nice. Great work.
Let's remember guys the center diff is an open 50/50 ratio.
An open diff, power can transfer up to 0/100 of the power to the side with less load. (My opinion is the rear because of less weight)
The ACD just limits that, and wants to keep it to a solid 50/50.
If anything the center diff is transfering the power
....the ACD can either Help or Restrict
The XML I was using mainly used delay in degrees (A-map)
And slip in percent (B-map and C-map)
So either my xmls or merlines xml
Higher numbers mean more oversteer
(Well because its open, maybe even longer)
Lower numbers do seem to give under steer
(Because its locking or locking more frequently)
To me merlines xmls look more like time delays (my opinion)
Like the stuff that merline found, I am gonna be playing with it for awhile to see what happens.
