tuning after cams
Old Oct 4, 2013 | 10:02 PM
Travenport's Avatar
tuning after cams
Hey all,
I'm having new cams installed and had a tuning question. I've read the beginners guide on how to tune, however, im a bit confused. The guide talks about logging at WOT, but with new cams installed, and no tune beforehand, shouldnt I be trying to aviod WOT since I could damage the engine.
How should I go about logging/tuning?
She is also throwing a code now for the pre-cat O2 sensor (P0134)...will this go away with proper tuning or should i look into getting a replacement?
Old Oct 5, 2013 | 01:03 AM
CDrinkH2O's Avatar
Originally Posted by Travenport
Hey all,
Download Evoscan and buy a Tactrix 1.3U from http://www.evoscan.com/evoscan-gps-o...flashing-cable
Learn to log before you start changing anything.
Old Oct 5, 2013 | 01:25 AM
AndyCT9W's Avatar
You will need to replace the oxygen sensor.
As for the tune, I'd ask around for some examples of what adjustments to the map you should be making to get you in the ball park. Or you could run an AEM fail safe wideband to stop you melting stuff.
Old Oct 5, 2013 | 07:53 AM
Travenport's Avatar
ive got an openport cable already and have logged it before cams, however with new cams in on stock maps I've read that WOT isnt safe.
So how do i go about logging if I cant WOT?
Old Oct 5, 2013 | 07:54 AM
Travenport's Avatar
thanks for the suggestion
Old Oct 6, 2013 | 02:19 AM
MercenaryX2's Avatar
Get your cams broken in and then go about tuning. If they truly are stock maps then you won't have to worry about your AFR's being too lean. Have you even fired up the car for the first time? Also it says you're in Wichita so you're fairly local to me (3.5 hrs). I might be able to help you some unless I'm too far out of your way for that.
Old Oct 6, 2013 | 04:37 AM
Travenport's Avatar
Thanks man ill shoot you a pm
maknuge
AEM EMS
10
Feb 8, 2017 09:39 PM
Evo47
Jan 3, 2017 06:43 AM
roni4g63
Nov 16, 2015 05:10 AM
DormantBeast
Mar 28, 2012 10:41 AM
Eisen7
Aug 30, 2010 02:52 PM
