ECU thinks I have a MAF again...
Old Nov 12, 2013 | 08:45 PM
Babs's Avatar
But I'm on SD...
So I was in EcuFlash today, felt like getting my Cosworth M3's to lope again. Adjusted the MIVEC numbers at idle, pressed "write to ECU", no biggie...I've been through this a million times. Halfway through the write, I got an error (forget what it said) and it said to press the "write to ECU" button again to finish writing the map. Well I did and it went fine.
However, I went to drive the car a little later and it ran like utter crap. Pulled the codes and I got a P0113, P0102, and a P2228...all of which I believe are MAF related. So I'm guessing the car is in some kind of limp mode right now because it's not getting any signal from the MAF, because there is no MAF.
So my question is, how do I get the ECU back to the way it was? I'm not a tuning guru so I'm not sure how SD exactly works, whether it disables the MAF or tricks it into thinking there's one or whatever...I don't know.
How do I disable the MAF and/or get the ECU to think the MAF is still there?
Thanks in advance!
EDIT: My rom is 88590015 if that helps any...I'm gonna need a step by step process because I'm clueless when it comes to tuning Evos. I can rip the motor apart and put it back together but tuning is beyond me.
Old Nov 12, 2013 | 09:41 PM
mitsubeastlee's Avatar
reflash the old rom back on to the car and try again
Old Nov 12, 2013 | 09:43 PM
Babs's Avatar
I did that and still no good. Not sure if I should clear the codes or pull the battery though. Would that do anything?
Thanks
Old Nov 13, 2013 | 04:18 AM
Babs's Avatar
Pulled the battery, reflashed the old map and it's still coming up with those codes so I'm guessing it still thinks it has a MAF.
Anybody???
Old Nov 13, 2013 | 06:03 AM
211Ratsbud's Avatar
You should hook a maf up to see if they go away with your current flash. Leave it in the intake tract too
Or
Flash an earlier base rom and eliminate the rom as corrupt. I've had a rom or two corrupt in me before
Old Nov 13, 2013 | 12:54 PM
domyz's Avatar
First: 88590015 is a MAF ROM. Is that a typo?
Second: Try a fresh tephra V7 ROM, new XML pack and copy over your tables. 100% sure that this procedure will solve your problem.
senate6268
Lancer Engine Management / Tuning Forums
91
Dec 26, 2022 12:20 AM
NZEvox
Feb 10, 2013 01:40 AM
Live4Redline
49
Aug 23, 2012 09:50 PM
techghost
May 1, 2012 12:41 PM
