94170715 V7 will not boost over 15 psi
Like title states I can not get boost over aprox. 15 psi. I have an Omni 4 bar so I am running 94170715 option 2.
I have read Raptord's write up many many many times maybe I am just missing somthing
https://www.evolutionm.net/forums/10647115-post3.html
I zeroed everything out and Started the BWGDC at 15% and slowly increased it but it will not boost over 15 psi.
Right now I have 255 walbro, an 02 elbow, coil on plug and Omni 4 bar. I am making a lower intercooler pipe this weekend. I will be doing evo 9 turbo, turbo back exhaust and the rest of the intercooler piping by the end of the year, then cams and injectors by feb. I would eventually like to go SD as well. Basically I wanted to get some of the knock out from the stock tune and I like the big maps of v7 I wanted to get a base set up to allow for future tuning. as far as boost goes prob around the 21psi & power low 300s hp
I'm assuming you just switched to v7 and your boost was fine prior to switching?
The stock BCS is nearly maxed out to reach 20psi on a stock car, so I would say keep increasing WGDC gradually. If you get to 100 across the board and still don't reach your normal boost, then something else may be wrong with how your rom is set up.
