EVO is pulling timing no knock
Old Jan 12, 2014 | 04:08 AM
nicolassabra's Avatar
Originally Posted by merlin.oz
Keep in mind that TephraMod 1-byte load will read higher than the load that is used in the spark map, which is baro compensated load plus modifiers like air temp subtraction.
If your 1-byte factor is 1.2 your measured load will top out at 306, this is why you would change it to read higher, but the 1-byte value in EvoScan has to match whats in your rom.
HEY
-so my timing map load bar isn't matching my 1-byte load evoscan reading because in the ignition map, load will top out at 350 witch should be topping out at 306 according to my 1-byte factor .
- As i understand i need to re-scale my load bar to match my load factors right?
Live4Redline
Jul 17, 2024 07:09 AM
EvilDSM97
Aug 29, 2022 09:02 AM
ehall20
Apr 5, 2014 05:26 PM
90zcrex
Nov 11, 2012 04:40 PM
GTR2009
12
Jul 22, 2009 12:46 PM
