TephraXMOD V2
Old Jul 27, 2014 | 09:23 AM
  #271
xBoostx's Avatar
Would I be able to flash back to completely stock and undo Tephramod V2 on my 2013 if need be?
Old Jul 27, 2014 | 10:14 AM
  #272
Hiboost's Avatar
Originally Posted by itzwolf
I've personally defined 2010, 2011, 2012, and 2013-14 GSR definitions to all match for my personal collection.
One day I'll get around to 2008 GSR (I started and got busy with other stuff) and SST ROM's.
I helped someone with a 2009 SST ROM also recently, believe it was 54070014 which was not defined at all.
And in reference to you flashing the 2010 ROM, the 2010 v2 ROM will NOT work on a 2011+ Evo, tephra believed its ETACS related and the new fast OBDII code. It bricked my ECU every time it was flashed and why he moved me to a 2013 ROM since the 2011 ROM was not finished at that point.
I have my 2011 bench flashed down to a 2010 ROM successfully, is it just something with the TehpraV2 that not allowing you to down rev as a bench flash or were you trying to flash it without benching? Once the 2010 code was bench flashed on my ECU i've literally written hundreds of re-flashes since then with success.
Old Jul 28, 2014 | 06:30 AM
  #273
itzwolf's Avatar
I was bench flashing. It would flash but at the end not display a VIN and be in a bricked mode (fans on high crank with no fire) and require a bench flash back to either a 2011 stock, V1 2010, or in my case a 2013 V2 ROM.
Its specific to V2 only and from what David said he thought it may be his new fast OBDII code and the 2011+ ETACS just not working together with a 2010 ROM.
I was successfully on a 2010 V1 ROM for a year or so before moving to V2. Now that brake boost and I've defined every known table in the public for the 2010 and up ROMs the 2010 ROM really isn't a big deal to me outside of the idle timing control. So I hope to see the idle timing map(s) found.
Old Jul 28, 2014 | 07:14 AM
  #274
Hiboost's Avatar
Oh I see, thanks for the heads up. Looks like I'll have to get an official 2011 ROM defined for my MR before I even think about V2.
Old Jul 28, 2014 | 11:39 AM
  #275
99EclipseGSX's Avatar
Yes. I've done this on a 2013 and gone back to a 100% stock ROM after having the Tephra V2 loaded. You'll need to bench flash it but it works fine.
Old Jul 29, 2014 | 07:49 AM
  #276
xBoostx's Avatar
Thanks man.
So I'll need a bench flash harness. Where can i get one?
Old Jul 29, 2014 | 08:03 AM
  #277
momostallion's Avatar
you have to make it.
http://www.evoxforums.com/forums/showthread.php?t=29820
Old Jul 29, 2014 | 08:09 AM
  #278
mclaren's Avatar
Thanks man.
Where you located?
Old Jul 29, 2014 | 03:22 PM
  #279
franzcars's Avatar
We send him money though the donations@globalshare.com correct?
Old Jul 29, 2014 | 07:01 PM
  #280
xBoostx's Avatar
Originally Posted by mclaren
Where you located?
Miami, Fl
Old Jul 29, 2014 | 07:04 PM
  #281
xBoostx's Avatar
Originally Posted by momostallion
Thanks for your help.
Old Jul 31, 2014 | 07:48 AM
  #282
LOVEMYX's Avatar
I cant thank You enough for V2. I absolutely love it! Thank you Tephra and Everyone who made Ecuflash possible! Thank you for your hard work!
Old Jul 31, 2014 | 09:02 PM
  #283
mkm492's Avatar
V2 for 2011 GSR
Already donated twice over the last year and a half in support of a straight-up V2 for the 2011 GSR. Is this something that is still in the works, or has it fallen to the wayside and folks are happy with a bench-flash to another model year? I just want it as a failsafe tune for running out of juice (Meth/H20.) I just have it set up to cut boost now for the failsafe, but it would be nice to have the option of not spraying. I can wait if its a pending release. Thanks
Old Aug 1, 2014 | 06:42 AM
  #284
mclaren's Avatar
2011 GSR/56890013 rom should be good to go for v2. I have been running with no issues since late April.
Old Aug 3, 2014 | 05:11 PM
  #285
rpizarro's Avatar
I need tephraXmod V2 from my 2009 EDM GSR? It's ECU ID is 54060007
