TephraXMOD V2
Is there a recent patch for 2012's? My car is currently at Boostin Performance (Chicago area) to get an MHI turbo installed along with supporting mods. The intent was to tune dual maps - one for 93 and the other for E85 using the tephra mod.
As I understand it they have a request out to tephra for a latest patch but haven't heard back. I pick the car up tomorrow pm. If they can't get the update from tephra I'll be stuck with one map (or buy a Cobb AP - which I prefer not to).
What's the best way to get tephra in concact with Boostin?
you can email tephra and ask then pay. he may be able to send it but likely boosting will have to bench flash it on.
V1? yes, i verified it for David way back when so yes i have V1.
Just have Boostin build two maps (or more) and save them separately.
Then when you get v1 or v2, you don't have to get re-tuned or more dyno time. just the maps copied to the right places and reflashed.
My understanding is that the stock ECU, unmodified/pathed, can not accept two maps. We were workign towards a solution where you push the gas pedal down (motor off) and the check engine light would flash - slow intervals for map 1/93 and then quickly for map 2/E85.
They mentioned I could do so with a laptop/cable or Cobb AP. I didn't want to spend $650 for the AP to switch maps because a patch isn't available. Do you recommend the laptop approach?
