TephraXMOD V2
Old Jul 7, 2014 | 10:04 AM
  #256
MashX's Avatar
I know there is a problem of how to show current map on SST. I think that 4-5 maps for SST for now would be enough. And it can be shown by fast blinking of CEL/FMIC icon during change of maps. It's easy to understand up to 5 blinks this way.
Or for example - long press cruise - blink X time to show which map is now. Within 3 seconds press cruise Y times (with interval not more than 1 second) - change map to that one and confirm it by blinking Y times... 10 maps is overkill anyway. I could see that way quite comfortable to use without messing with tachometer.
Old Jul 8, 2014 | 11:49 PM
  #257
gsxrmel's Avatar
yes i think also with 4 5 maps or less will be enough.
v2 for sst!!! please!!!
regards!
Old Jul 9, 2014 | 06:24 AM
  #258
8OhOh2's Avatar
I don't think we got an answer about those of us waiting for maps - Should we donate now or wait until it is available?
Old Jul 14, 2014 | 10:41 PM
  #259
mrwickd123's Avatar
V2 for sst!!! Please!!!
Regards!
+1
Old Jul 15, 2014 | 09:06 PM
  #260
nandoliver's Avatar
Originally Posted by tephra
I am sure he does
I've been submitting XML changes to him, so im waiting on a refreshed version that I can say is upto my standard
Hi tephra
I have question regarding XMODV1 and XMODV2. Do you think any of the versions will work with a 1xxx hp build and 50+ psi of boost without problems? Do you think is possible to use it just with the MAP sensor instead of MAF and MAP?
If any of the existing versions or a new one can be used, please let me know, the shop is willing to pay for it if necessary. You can contact me at nandoliver{at}gmail{dot}com
Thank you!
Old Jul 16, 2014 | 05:20 AM
  #261
Hiboost's Avatar
regards!
+1000
Old Jul 17, 2014 | 10:07 AM
  #262
bellacotim's Avatar
@ Tephra, even if you limit XMod V2 on MRs to two maps, you're sure to have a large willing customer base, hungry to pay you for what you have NOW. Do it and charge MRs a few $$$ less, then solve the tacho-map bug later as a $$$ upgrade.
2011-2015 MR owners will thank you.
Old Jul 18, 2014 | 09:10 AM
  #263
palmerblock's Avatar
@tephra... Sent over a payment for a 2013 gsr I'm currently working on in Georgia. Sent a email also.
Old Jul 18, 2014 | 09:39 AM
  #264
momostallion's Avatar
would we say that 2010 usdm (55570006) would be the most well defined rom?
if so, rather than wait for 2012 and since i have to bench flash anyway, i might as well do 2010 right?
Old Jul 18, 2014 | 11:43 AM
  #265
itzwolf's Avatar
I've personally defined 2010, 2011, 2012, and 2013-14 GSR definitions to all match for my personal collection.
One day I'll get around to 2008 GSR (I started and got busy with other stuff) and SST ROM's.
I helped someone with a 2009 SST ROM also recently, believe it was 54070014 which was not defined at all.
And in reference to you flashing the 2010 ROM, the 2010 v2 ROM will NOT work on a 2011+ Evo, tephra believed its ETACS related and the new fast OBDII code. It bricked my ECU every time it was flashed and why he moved me to a 2013 ROM since the 2011 ROM was not finished at that point.
Old Jul 18, 2014 | 12:54 PM
  #266
ah okay. maybe i should also go to 2013.
i know my 2012 definitions have a bit more than what ecuflash comes with now or what was on goldens site cause i just matched addresses against 2010 known tables.
Old Jul 18, 2014 | 05:33 PM
  #267
bellacotim's Avatar
I've got 2013 SST fully defined to the levels of the above 2013 GSR. Hit me up if you want.
Old Jul 22, 2014 | 02:22 PM
  #268
franzcars's Avatar
Originally Posted by llabmik2
Has anyone found out if this is the Beta that allows flashing without benching?
Old Jul 22, 2014 | 08:46 PM
  #269
jerome6590's Avatar
2012 flash
Does this mean there's still no flash for the 2012 usdm gsr? I've read just about the entire post and not seen anyone make a definitive statement about what to do for us guys with the '12. This mod is really cool and I'm a perfectionist so if we need to wait then I'll just sit here patiently.
Old Jul 26, 2014 | 08:24 PM
  #270
RngrYogi's Avatar
I will pay if the 2008 USDM MR 52690021 becomes available. If so please update me at RngrYogi(at)gmail(dot)com
