Evo 8 ECU to Evo 5 Engine
Old Mar 19, 2014 | 12:47 AM
jmb_silvester's Avatar
Hi Everyone, Is it ok to use a Evo 8 ECU to Evo 5 Engine? Is there any modification that need to do for this to work? or this is just plug and play and remmap?
Old Mar 19, 2014 | 02:06 PM
todd6027's Avatar
if its an evo8 4 plug ecu its easier, you need to swap some ecu pins and wires then switch off egr etc in the rom.
some more info here
https://www.evolutionm.net/forums/ec...t=evo8+ecu+evo
Old Mar 19, 2014 | 06:11 PM
some more info here
Thanks buddy this is a big help
Old Mar 19, 2014 | 06:33 PM
one more thing, what advantage can i get if i replace my ecu with evo8 ecu?
Old Mar 20, 2014 | 02:57 PM
todd6027's Avatar
there is none now is was a common to fit evo 7or 8 ecus to the earlier models before 5/6 ecus could be mapped with ecuflash
Old Mar 20, 2014 | 11:38 PM
GregM's Avatar
Agree, none, I'm running SD on my evo 5 ecu and the rom does everything an 8 one can.
Old Mar 23, 2014 | 06:07 PM
wreckleford's Avatar
I haven't been following up on the H8 ecu recently. Are larger fuel and timing maps available now?
Old Mar 24, 2014 | 01:28 PM
pheoxs's Avatar
Are you using the openport 2.0 cable? I was trying to figure out what I can use with my EVO 6 but it looks like the 1.3 cable isn't supported for the Evo 4/5/6?
Old Mar 25, 2014 | 01:08 PM
todd6027's Avatar
has to be the op2 cable
Old Mar 25, 2014 | 02:43 PM
CP9A-Will's Avatar
op2 worked on my 6 but i had to jump 2 pins with a paperclip. i forget which ones they were.
Old May 17, 2014 | 11:20 PM
LJ7two4's Avatar
Sorry to bring up an old thread but is tuning the Evo 5 ecu the same as tuning an evo 8 ecu? Is support as widely available for the 5 as the 8 in terms of tuning through ECUflash?
Old May 18, 2014 | 04:34 AM
todd6027's Avatar
same methods and support , fuel trims work differently so just get the low trim to within +/- 5 % as it maxes out at =/- 4.8
Old May 18, 2014 | 10:04 AM
LJ7two4's Avatar
Thank you so much, good to know! it is much easier to find an evo 8 ecu so I thought I'd give the evo 8 ecu a shot for the time being. I borrowed one that my friend had for sale and he said I could return it if it doesnt work out. Plus the fact that there is the 7202 and 7203 variance in the V ecu scares me...
Hopefully no hiccups, I will be using an extension harness(AEM or APexi?) because I am scared to cut or splice anything from my factory ecu harness
anybody got a preference on brand between those two?
Blackie9900
For Sale - Part Outs
Oct 25, 2016 05:39 AM
1091x
Jul 20, 2016 06:22 PM
1091x
Jul 18, 2016 12:03 PM
Migsubishi
May 11, 2016 05:28 AM
SPC Perrault
150
Sep 7, 2011 09:24 AM
