03 Lancer automatic ecu-> evo8 rom?
Old Mar 25, 2014 | 05:51 PM
typeRA's Avatar
Hi, I'm new to the evolution ecus, and I've tried finding a sure answer to whether or not an auto ecu can be flashed to an evo8 ecu for use on a stick car.
I'm abandoning the dsm ecu in hopes for your much more advanced coding and development
regards
Old Mar 26, 2014 | 06:24 AM
Broke4speed's Avatar
Yep, you definitely can. That's how I run my 1G swap . I'm currently using an 02 Lancer A/T ecu with the Tephra V7 rom.
You have to alter the xml though, otherwise it won't open the file. You need to change the memmodel to "<memmodel>SH7055</memmodel>", and double the size of the M/T rom you plan to use. The stock M/T stuff is 256kb, and the A/T is 512kb. I've enclosed my files below, to make it easier .
File Type: bin
Old Mar 26, 2014 | 06:52 AM
wreckleford's Avatar
Also keep in mind that the ECU will nto plug up to a 2G harness. You will need to build an adapter.
Old Mar 26, 2014 | 07:15 AM
Ah, yeah, definitely. Here's the pinout I used for the 1G DSM - to - AT ecu.
If anything, it'll help you with some of the pinouts you'll need to build the adapter.
http://www3.sympatico.ca/tchaad/Lanc...M%20pinout.xls
Old Mar 26, 2014 | 01:50 PM
typeRA's Avatar
thanks a ton guys. i snagged the pigtails of the donor lancer, so i think im going to make an adapter with the guts of a non eprom ecu. thanks again
real fast
Jan 21, 2013 07:18 PM
DRT EVO
Jan 19, 2012 09:39 AM
Ganabi
Dec 16, 2011 04:49 AM
kasipong
Aug 8, 2011 11:35 PM
