Need help evo 8 map no start
Old Mar 29, 2014 | 01:10 PM
BOOSTDBSTRD's Avatar
NEED HELP!!! so I built my 2005 evo 8 did a 2.4 LONG ROD stroker
11:5.1 compression
ported and polished head with 1mm oversized valves
fully built bottom end
ELECTRONICS
2000 ID injectors
OMNI 4 BAR
GRIMMSPEED EBC
AEM AIT
4 channel sparktech CDI
RUNS ON E85
OK so what happened is I built my car I had an 03 evo with all the tephra mods on the ecu so I stole the map off it just to start the car. I know how to tune but I DO NOT UNDERSTAND XML CODE AND ALL THAT JAZZ. so i got the car to at-lest run with the 03 evo map I had to run as much as 8.9 fuel in the map so SCALING is what is wrong. I scaled the injectors to 1083 E85
someone tried to send me a base map so i can tune the car but it will not start
disabled the immobilizer and car still does not start with the map so im back to my old map
WHEN LOGGING I KNOTICE
that the map sensor reads 10 lbs of boost at idle this has to be the problem to a point
IM LOOKING FOR SOME HELP SO I CAN FINALLY ENJOY MY CAR
PLEASE MSG HERE OR IF YOU WANT TO TRY TO REACH ME FAST TO ASK QUESTIONS PLEASE CALL OR TEXT 208-954-2565 THANKS GUYS MEANS ALOT
Old Mar 31, 2014 | 06:46 PM
I take it nobody knows
Old Apr 1, 2014 | 09:14 AM
X Double Dot's Avatar
Sure its not 10 psi of vacuum? Is it a stock map sensor? Make sure ur scaling is right. If ur logging, check what load cells you are actually running in on the ignition map. Are the idle afrs close?
Old Apr 2, 2014 | 03:57 PM
Dmek1498's Avatar
Bump
Old Apr 7, 2014 | 02:39 PM
I got it set someone called me and helped me a ton. the car didn't make it off the dyno though had a ring break or I spun a bearing so Ill get that fixed and be back at it asap.
Fast_Freddie
Oct 30, 2023 01:56 AM
r4p.t0x
Jun 29, 2014 10:17 AM
CtSilver03Evo
Cobb AccessPORT
Jun 4, 2014 04:38 PM
scheides
E85 / Ethanol
28
Nov 30, 2008 11:29 AM
