Ugly rough fuel map
Old Apr 16, 2014 | 09:47 PM
TurboTylerIX's Avatar
Ugly rough fuel map
Hi guys,
I want some feedback on my fuel map. It's not done but I don't like the shape it's taking. There are areas where the values in the cells a far apart from each other in order to get the same or close actual AFR from wideband.... it seems it wants to be rough.
What is the best workflow for tuning on the street? Do you guys use map tracer in evoscan to make tuning changes or do you look at the raw csv log and make changes based on looking at that in ecuflash?
Old Apr 17, 2014 | 04:50 AM
Raptord's Avatar
I look at the raw log and I believe more tuners do as well.
Did you make any changes to your MAF scaling? If it was scaling weirdly it could explain the weird shape your map needs to have a smooth AFR.
Old Apr 17, 2014 | 09:57 AM
I'm pretty sure my MAF scaling is stock. I know I tried scaling it years ago but im pretty sure i gave up and put it back to stock. Should I try to scale it again?
I just got my 2.3L running a few days ago so I'm working on the tune now using my old 2.0L tune as a base. I've pulled timing almost everywhere, and lowered boost. It's 10:1 on CA 91 octane + meth.
Is it normal for a fuel map to look rough like mine or am I doing something wrong?
Why do you and other tuners prefer to look at the raw log? Isn't it more difficult/time consuming or does map tracer not yield good results?
Old Apr 17, 2014 | 10:59 AM
todd6027's Avatar
As said use the raw log , rather than making one particular cell really rich to acquire the relevant afr keep it smooth with the adjacent cells and bring those up or down a little rather than one up or down a lot
Old Apr 17, 2014 | 11:25 AM
OK makes sense, thanks. I have tried tuning all different ways, but haven't settled in to a way that I comfortable with. Just trying to figure out how the pro's do it
So is it ok to leave my MAF scaling stock even with a 3" hardpipe intake, 2.3L, etc. ??
Old Apr 17, 2014 | 02:03 PM
todd6027's Avatar
I rarely touch the maf scaling other than to correct low fuel trim , im using the stock maf scaling on 2.3 mivec , s2 cams hardpipes etc
TurboTylerIX
For Sale - Wheels / Tires
Oct 1, 2014 09:15 PM
TurboTylerIX
Jun 7, 2014 08:41 AM
TurboTylerIX
15
Nov 3, 2013 10:49 PM
TurboTylerIX
Oct 1, 2008 09:57 AM
TurboTylerIX
Jul 12, 2008 06:59 PM
