my 'Boost Desired Engine PSI' is wrong
I'm no tuner, but I was poking around in my ROM today and noticed my 'Boost Desired Engine PSI' only goes up to 11psi. Interesting, because I've only been hitting 10psi for some time now, and I've been going crazy trying to find this "boost leak." Would anyone mind taking a picture of theirs and showing it to me?
[IMG]
[/IMG]
EDIT: Actually if someone wouldn't mind checking out my ROM that would be great. Who knows what else is changed and why. (I bought this ECU from a supposedly unmodified Evo 8 but the injectors were set at 1000cc)
[IMG]
[/IMG]EDIT: Actually if someone wouldn't mind checking out my ROM that would be great. Who knows what else is changed and why. (I bought this ECU from a supposedly unmodified Evo 8 but the injectors were set at 1000cc)
my map looks different from yours. maybe I'm using an old version of ecuflash? Mine says boost desired engine load and shows percentage instead of actual psi. From what I remember though, this is actually on top of the boost load offset, but if you have a boost gauge that actually reads 10psi then you might have that missing boost pill, or like you said your rom might have been modified.
That's a Tephra V7 map. Most certainly not stock.
You should read up on PSI based tuning. Are your BCS and MAP stock?
I don't have your ROM ID on my PC, so I can't check it out.
05-EVO-GSR
Evo X Dyno Results
32
Jul 31, 2014 09:40 PM
woodyqb
For Sale - Cars For Sale
11
Feb 4, 2013 03:24 PM
