Need some help with 52360018 def
Old Sep 5, 2014 | 12:56 PM
ecktt's Avatar
I think the def that either came with or downloaded by ecuflash for a 52360018 rom might be a little off. Almost every thing seems correct.The mode 23 tables cannot be edited. Instead they show Disabled. If you add the mode 23 tables , you can then change the values and the stock tables will also change to enabled. Also the DoMode original value is 0x4242 instead of the suggested 0x42. The stock Boost target Engine load tables looks nothing like what Merlin tuning guide has.
Am I being paranoid or is something genuinely wrong?
Stock rom:
https://www.dropbox.com/s/4w6f78jxde...stock.bin?dl=0
Boost target engine load:
https://www.dropbox.com/s/vasgy2tynu...ables.PNG?dl=0
The xml I editied:
https://www.dropbox.com/s/p60zmtjmed...205MT.xml?dl=0
richardjh
Nov 6, 2024 04:41 AM
mrfred
Feb 26, 2022 06:16 PM
tephra
Aug 29, 2021 04:47 AM
richardjh
Jul 28, 2017 03:49 PM
chamelieon
33
Mar 3, 2015 05:22 PM
