GSC R2 Stroker Cams Preliminary Testing and data!
Old Feb 19, 2013 | 10:03 AM
chamelieon's Avatar
Just got my hands on the newly released GSC R2 Cams designed for stroker setups with big turbos due to highler lift and less duration, emphasizing power below 8500. Had GSC S2 previously which i didnt get to do any dyno runs yet due to being a fresh build and had the opportunity to try these new bump sticks out, although i did want a comparison i was able to get some evoscan virtual dyno data of both cams.
Motor Specs.
2.4LR Manley TT & CP 10.1's
Unported evo 9 mivec head
chameleontuning cop kit
Supertech dual springs
Unported Stock IM & TB
Unported Exh Manifold
Unported FPBlack JB
3" DP and 3" Aluminum Exh
ETS 3.5" Cooler and custom 2.5 piping
E85 SD
cam info and pics.
Installation process.. already had my cams out so 1hr job.
all done!
S2(red) vs R2(blue) evoscan dyno
Runs were done 1 week apart, same conditions, road, temps, keeping as much as possible the same. using an FP 25psi WGSA unloaded with no boost controller would start @ 19-20psi and creep to 22-23psi.
R2 cams had a 1lb boost advantage up top, but very top of the rpm range.
R2 (blue load) S2 (purple load)
First startup
Idle
updated with dyno results: https://www.evolutionm.net/forums/ev...d-results.html
Old Feb 19, 2013 | 10:41 AM
SWOLN's Avatar
Nice work, sounds good too.
...back in the day it would have been unheard of to get cams like these to idle, with big injectors, on the stock ECU. Progress is great.
Old Feb 19, 2013 | 11:23 AM
jezzy101's Avatar
Veteran: Marine Corp
Thanks for the info bro
Old Feb 19, 2013 | 03:59 PM
R/TErnie's Avatar
awesome results! We picked a winner!
Old Feb 19, 2013 | 04:21 PM
JohnBradley's Avatar
Thank you for the very thorough review.
Old Feb 19, 2013 | 09:22 PM
17pstockcar's Avatar
They sound great
Thank you very much
Old Feb 20, 2013 | 03:06 PM
sktng22's Avatar
woulda thought these things would have a lumpier idle then that...
Old Feb 20, 2013 | 05:39 PM
In the VIII they do. These cams have had quite a lot of engineering to make them do what we want. The fact they are as aggressive as they are and idle close to stock is the best part.
Old Feb 20, 2013 | 08:43 PM
2001gslp's Avatar
How would these perform while using a stock IX turbo on a built 4G64 with an VIII head? Would it be better for me to use S2's than these or stick with stocker's?
Old Feb 21, 2013 | 03:47 PM
If its a stock head they arent for you. In all the testing with all the turbos we have used with these cams they need larger turbos to shine and a good cylinder head.
Old Feb 21, 2013 | 06:11 PM
Craig King's Avatar
No lopey idle, no care.
Old Feb 21, 2013 | 06:29 PM
luis!'s Avatar
Great review. OP, are you going to be selling your S2's?
Old Feb 21, 2013 | 08:21 PM
2001gslp's Avatar
@john: it's a g4js head with the viii valvetrain, complete pnp, manley springs, maybe gsc zero tick lifters, and still debating on oversize valves.
Old Feb 22, 2013 | 05:56 AM
R/TErnie's Avatar
Craig... It's a mivec car. He's got the intake cam at full retard at idle so it doesn't lope. Advance that cam 10 degrees and it'll lope like nobodies business!
Old Feb 22, 2013 | 01:15 PM
Joshs EVO's Avatar
Would these cams be better than the STM650's?
