Two Step limiter not working??
Old Sep 24, 2014 | 04:43 AM
VRP's Avatar
VRP
Evo 8 on a starter tephra 7 tune, the stationary Rev limiter is @ 5000rpm, it just shoots right past it? Anyone else have this issue? On the stock tune with limiter set it functions properly...
Old Sep 24, 2014 | 05:59 AM
detroit pistins's Avatar
Look under “Tephra Mod Options”… are “Enable Launch maps” enabled or set to “1”
Also, look under “Global Launch maps”…..what are your TPS and speed thresholds?
Old Sep 24, 2014 | 06:35 AM
VRP's Avatar
VRP
I'll take a look for that when I'm home.
Old Sep 26, 2014 | 07:41 AM
VRP's Avatar
VRP
launch maps were disabled lol..
Old Sep 26, 2014 | 08:56 AM
Although the stationary limiter should be limiting the rpm regardless of spark, so give it and see if it fixes ur issue.
Old Sep 26, 2014 | 11:40 AM
VRP's Avatar
VRP
still doesnt work!
Old Sep 26, 2014 | 02:12 PM
VRP's Avatar
VRP
Tps threshold is 40%
Old Sep 26, 2014 | 11:28 PM
Can you post your rom or email it to me?
Old Sep 27, 2014 | 01:04 AM
thatguy5's Avatar
could it be that your clutch sensor is unplugged? I had my 2step set to 5800 but it didnt work until I plugged my clutch sensor in.
Old Sep 27, 2014 | 03:48 AM
VRP's Avatar
VRP
As soon as the stock tune is back on the launch limiter works... Not Mechanical
Old Oct 1, 2014 | 05:17 AM
VRP's Avatar
VRP
Any ideas?
Old Oct 1, 2014 | 05:40 AM
did u check the rev limiter vs stationary limiter?
Old Oct 1, 2014 | 05:42 AM
VRP's Avatar
VRP
Yea its stationary rev limiter 5500, like I said it functions perfectly on the stock tune at 5500, nothing on tephra.
Old Oct 1, 2014 | 11:45 AM
R. Mutt's Avatar
The stationary rev limiter and launch maps are separate things. You do not have to switch on launch maps to utilize the stationary rev limiter.
OP - check that FEA bit 8 is on (clutch pedal circuit):
Old Oct 1, 2014 | 07:40 PM
VRP's Avatar
VRP
Clutch pedal circuit was not activated! Will try that tomorrow thanks.
