Theres a Trick to run stock maf without air intake?
Old Nov 3, 2014 | 08:27 AM
Mauricio Evo IV's Avatar
Theres a Trick to ecu to run stock maf without air intake?
Hello guys.
I put in my Evo a new turbo PTE 6266. Before that I used a FP Black.
The thing is, the air intake for that turbo is retained in custom in my country, so I need to move my car but I dont have the inlet, and I am use the stock maf. I start the car without air intake and sucks.
My question is, theres a way to trick the stock ecu for run my car without the air intake?
I will apreciate your help. thanx!
Old Nov 3, 2014 | 02:24 PM
robbyredneck's Avatar
Yes set up speed density. Or make a temporary intake
Old Nov 3, 2014 | 05:02 PM
merlin.oz's Avatar
or reduce the values in the limp home map by about 35% as you are using 1000cc/min injectors.
Old Nov 4, 2014 | 06:16 AM
Yes man, I got a reductor and made a temporary intake. Thanx!
Old Nov 4, 2014 | 06:18 AM
Hello man, right now the car has FIC 1,100cc high impedance. The problem now theres not the intake, its the tune. The car sucks, idle in 10.9-11.9-12.1 very bad
Old Nov 5, 2014 | 02:23 AM
Biggy VIII's Avatar
Could you give an xml definition for that map for 9653 and 8859 roms please?
Old Nov 5, 2014 | 05:10 AM
stunt2's Avatar
unplug the connector from the maf
worked for my car to move between several shops while I was in process of swapping turbos like you
not the best driveability but unplugged maf was way better for me while running without intake pipe
run very rich but was driveable to move the car on short distances
Old Nov 10, 2014 | 12:32 PM
Thank you very much man!!
CristianRO
Nov 27, 2017 07:23 AM
Jedi_Gill
24
Apr 1, 2011 02:29 PM
4g63smokinall4s
28
Dec 4, 2009 07:18 PM
Arithmetic
Lancer Troubleshooting
29
May 5, 2004 09:12 AM
