Need assistance in defining fuel accel enrichment for 56920008
Hi all. Have recently run into an issue with my evo x. Currently I am running e85 with 1600cc injectors and have a slight issue with lean afr when going from idle to light cruise. Unfortunately, my rom does not have the following defined:
Asynchronous Injection - TPS Accel - ECT Based adder
Asynchronous Injection - TPS Accel - RPM Based adder
Asynchronous Injection - TPS Accel - Max TPS Threshold
Asynchronous Injection - TPS Accel - Max IPW Limit
Asynchronous Injection - TPS Accel - IPW per change in TPS
If I could be pointed into the right direction, it would be much appreciated
Here you go, let me know how it works out for you.
Code:
<table name="Asynchronous Injection - TPS Accel - Adder ECT based" address="55818" category="Fuel" type="2D" level="2" scaling="uint8"> <table name="ECT" address="618C2" type="Y Axis" elements="8" scaling="Temp"/> </table> <table name="Asynchronous Injection - TPS Accel - Adder RPM based" address="5A4AA" category="Fuel" type="2D" level="2" scaling="uint8"> <table name="RPM" address="5D5E2" type="Y Axis" elements="16" scaling="RPM"/> </table> <table name="Asynchronous Injection - TPS Accel - Max TPS Threshold" address="55804" category="Fuel" type="2D" level="2" scaling="Percent255"> <table name="RPM" address="61606" type="Y Axis" elements="16" scaling="RPM"/> </table> <table name="Asynchronous Injection - TPS Accel - Max IPW Limit" address="5310E" category="Fuel" type="1D" level="2" scaling="IPW 2byte"/> <table name="Asynchronous Injection - TPS Accel - IPW per change in TPS" address="557F7" category="Fuel" type="2D" level="2" scaling="IPW"> <table name="Change in TPS" type="Static Y Axis" elements="9"> <data>0</data> <data>12.5</data> <data>25.0</data> <data>37.5</data> <data>50.0</data> <data>62.5</data> <data>75.0</data> <data>87.5</data> <data>100</data> </table> </table>
Charlie_B
Apr 27, 2009 09:52 AM
mrfred
Apr 1, 2009 05:00 PM
