HOW TO: Improving SST Throttle Response
Old Dec 25, 2014 | 05:56 PM
RS200Z's Avatar
Here's a tweak that I have been using for a while. For those who aren't aware, the various SST modes (Normal, Sport, S-Sport) affects the shift point (RPM), shift speed, clamping pressure as well as throttle response.
Apart from the SST Throttle Requested Torque Ramp Rate tables which you can tweak, there's a few other "Unknown" tables which can be tweaked for further response improvement.
But first, thanks to Richard (richardjh) and Bryan (razorlab) for the SST Tables thread back in 2012: https://www.evolutionm.net/forums/ec...nt-thread.html
However, the SST Unknown #1 to #5 tables are not correctly named. Richard subsequently provided the correct description which prompted me to explore further.
Here's how I have named them in my XML:
The tables of interest here are the Unknown #3 to #5 for the various SST modes. For those looking for a quick and dirty way to tweak them is to simply copy the values from the 2011 onwards model for table SST Unknown #3 and #4.
You should see noticeable improvement for both the Normal and Sport mode.
Unknown #5 (Super Sport) table is the same for 2008 to 2014 models from what I have seen so far.
Have fun and Merry Christmas!
2008 Model:
2011+ Model:
Attached Thumbnails HOW TO: Improving SST Throttle Response-sst-unknown-tables.png   HOW TO: Improving SST Throttle Response-08-unknown-3.png   HOW TO: Improving SST Throttle Response-08-unknown-4.png   HOW TO: Improving SST Throttle Response-12-unknown-3.png   HOW TO: Improving SST Throttle Response-12-unknown-4.png
Old Dec 25, 2014 | 05:57 PM
RS200Z's Avatar
*Reserved for XML Definitions*
52690019 / 52690021 - 2008 USDM SST
Code:
<scaling name="AcceleratorPedal1024 %" units="%" toexpr="100*x/1024" frexpr="x/100*1024" format="%.1f" min="0" max="100" inc="0.5" storagetype="uint16" endian="big"/>
<table name="SST Unknown #3 - APP Mapping/Ratio, NORMAL Mode, Gears 2+" category="SST" address="585e3" type="3D" level="3" scaling="uint8">
  <table name="Accelerator Pedal" address="61874" type="X Axis" elements="27" scaling="AcceleratorPedal1024 %"/>
  <table name="RPM" address="618ec" type="Y Axis" elements="12" scaling="RPM"/>
</table>
<table name="SST Unknown #4 - APP Mapping/Ratio, SPORT Mode, Gears 2+" category="SST" address="5872f" type="3D" level="3" scaling="uint8">
</table>
<table name="SST Unknown #5 - APP Mapping/Ratio, S-Sport Mode, Gears 2+" category="SST" address="5887b" type="3D" level="3" scaling="uint8">
</table>
Old Dec 26, 2014 | 04:20 PM
rpacheco's Avatar
I've tuned these tables as well. Try the following scale for APP and you'll see it makes a lot more sense.
Code:
</table>
</table>
</table>
Old Dec 26, 2014 | 08:00 PM
itzwolf's Avatar
Images are not showing up for me...
Old Dec 28, 2014 | 02:01 AM
RS200Z's Avatar
Yeah, thanks a bunch for the APP scaling. Have updated my post with that.
Old Jan 10, 2015 | 12:43 AM
xminos's Avatar
Same...and I'd love to see them :/
Old Jan 17, 2015 | 02:52 PM
merlin.oz's Avatar
None of the attachments in the first post are opening.
Old Jan 18, 2015 | 04:19 AM
RS200Z's Avatar
Not sure what happened previously to the images, but hopefully it's fixed now. At least it showed up ok for me.
Old Jan 18, 2015 | 01:42 PM
xminos's Avatar
Work now for me. Thanks. Just had to login to view (didn't previously work at all).
Thanks again dude!
Old Jan 20, 2015 | 02:39 PM
gsxrmel's Avatar
ho have the 53050012 hex with all the correct xml with this tables also?
i have now 53050009, with this update rom the car will be run bether?
regards
superscout03
Apr 10, 2006 10:57 PM
megatron
Jan 15, 2005 07:55 AM
rickpyle
Lancer Troubleshooting
15
Feb 26, 2004 11:41 AM
StinkyTofu
Nov 24, 2003 06:21 PM
mayhem
Aug 29, 2003 11:28 AM
