please help, 03 evo ecu possible brick
(resolved) please help, 03 evo ecu possible brick
I have been searching frantically for the last couple hours with no luck.
I have a 2003 evo 8 and I was in the middle of a flash and my pc decided it wanted to install updates so it shut down in the middle of a flash, I was an idiot and immediately turned the car off and went inside to get online to see what to do and I did read that if I hadnt done that, then I wouldn't be in the situation I am in which is a possible bricked ecu.
I cant get it to take a flash or read anything from it and the car will not start. I am reading 11.9 volts at the battery and still nothing. I posted up the log of when I try to flash, PLEASE PLEASE PLEASE help.
Thanks!
Thanks!
ok quick update. I did a ton of reading last night and it appears there isnt much info on the ECU for the 7 8 and 9 bricking because they dont brick as bad as the X. I unplugged everything and let my battery sit for a while, I discovered the cable had a loose wire and so I fixed that. That fixed the car, it took a new flash like a champ and fires up. So if someone reads this down the road and is having issues, CHECK YOUR TACTRIX CABLE!
-Mike
Tactrix
Raceghost
Jun 1, 2016 12:30 AM
NOMIEZVR4
Oct 16, 2011 03:34 PM
EVOXcellence
Canadian Forum
May 1, 2011 01:29 PM
