tomei poncams, mivec settings nad two blown turbos...
Old Mar 25, 2015 | 05:04 AM
evoxuser's Avatar
Hi. I have Tommei poncam cams installed, and i use tommei rec. mivec settings: ( att )
exhaust:
2500 - 3500rpm -30 and etc. at load > 120.
I never sean any surge, my afr is ~12, egt 800C at max and no knocks at all.
But over the past two months I have killed 2 new stoc turbos ( TD05H-152G6-12T )
Could this be due for such mivec settings?
Attached Thumbnails tomei poncams, mivec settings nad two blown turbos...-tomeityperponcamevoxdsgperformance.jpg
Old Mar 25, 2015 | 08:58 PM
simonpvs's Avatar
The mivec timing on that isn't dissimilar from mine, however, I run 25 rather than 30 degrees on the exhaust during spool. Any more than that and I got surge with an FP red......
I'd start with the basics, oil feed line/return/boost leaks etc
You could have a partially blocked oil line
You could be over spinning it to hit your boost/load numbers due to boost leaks etc.....
Other than that, time to speak to a tuner.......
Old Mar 27, 2015 | 12:02 PM
evoxuser's Avatar
2 simonpvs tnx, it was boost leak.
Old Mar 30, 2015 | 07:55 AM
xBoostx's Avatar
props for posting solution. Helps others who may find themselves in a similar situation.
Some people ask for help then find a solution and never post.
Old Mar 31, 2015 | 06:13 AM
simonpvs's Avatar
Ouch, expensive boost leak.
Old May 24, 2015 | 07:16 PM
wilkes.1768's Avatar
Jeez, no good
4g63kid
Oct 28, 2015 09:22 AM
C00LM4N
Aug 11, 2013 09:32 AM
STM Tuned
EvoX 'For Sale' Engine Internals and Drivetrain
Aug 7, 2013 09:14 AM
jdowd
23
Jan 23, 2010 09:56 PM
SHIFTT IX MR
10
Sep 9, 2009 03:34 PM
