SD - AIT or Fuel temp ?
Old May 11, 2015 | 12:34 PM
tsitalon1's Avatar
Thinking of converting my USDM IX to SD
Car is 99% street driven in town.
I live in the Southeast and do not travel far, but maybe once a year.
Can I just use the Fuel Temp sensor, or is it much better to have an AIT welded into position?
Old May 11, 2015 | 04:17 PM
LetsGetThisDone's Avatar
I've been using fuel temp, as well as most other guys in my area. Seems to work fine.
Old May 12, 2015 | 07:30 AM
tsitalon1's Avatar
Good to know, I'll start working on the conversion then
Wonder why people go through the trouble of an AIT then...
Thank you!
Old May 12, 2015 | 12:25 PM
amilcarw's Avatar
so i dont need the extremepsi kit ???... for sd
Old May 12, 2015 | 12:29 PM
e_kobz's Avatar
If I recall Aaron, JohnBradley, from ER wrote a thread on using fuel temp for SD and it working just fine.
Old May 12, 2015 | 01:00 PM
you still need a 3 or 4 MAP bar sensor. Either a JDM MAP sensor, or one from OMNI..
Old May 12, 2015 | 02:23 PM
mgrover1's Avatar
I have my 8 converted to speed density using fuel temp with the omni 4 bar on the tephra 7 rom and after tuning it it runs flawlessly. just make sure to spend time on the tune
Old May 12, 2015 | 02:34 PM
tsitalon1's Avatar
Will do, thank you everyone.
Old Jun 21, 2021 | 04:44 AM
Rovin Raj's Avatar
IAT or FUeL temp
I recently tuned using Fuel temp for my lancer (4g93) it is showing me consistently 25c so i believe it is running based on fix temp. Can i use IAT? (i have one working well)
my issue is cold start is kinda bad. At least for first 1 min it will be low RPM before it increase.
any help?
Apex Hunter
May 21, 2016 06:17 PM
nemosEVO
Mar 27, 2008 01:07 AM
edison
Sep 24, 2006 09:54 AM
jbigelow
14
May 3, 2005 08:46 AM
