Flex Fuel testing in TephraXMOD V3
Old Dec 20, 2016 | 10:01 AM
  #256
Angeltownracing's Avatar
Originally Posted by tephra
Still nothing.. ??
thank you for answer. I just resent the mail.
Old Jan 7, 2017 | 02:02 PM
  #257
Tagesson's Avatar
Ecuflash has the wrong axis for this table...
This:
Code:
<table name="Injector Battery Voltage Latency Compensation" address="556d0" scaling="InjectorLatency">
    <table name="Battery Voltage" address="6536a"/>
</table>
Should be this:
Code:
    <table name="Battery Voltage" address="61082"/>
</table>
Hello Tephra I have now solved the problem with the address 61082, had to change it directly in romme Data 55570005 2010 USDM Lancer Evolution X 5MT. (XML)
Now I get one alarm on the X axis "map base load Cal # 1 hot / interpolated"
now the adress for psi is 62c88. (in XML)
Old Jan 16, 2017 | 08:36 PM
  #258
fas-n-furyus's Avatar
I am also getting the same error with Tephra Xmod V3 56910309
Old Jan 22, 2017 | 08:37 PM
  #259
Chet3215's Avatar
Can anyone go into detail about the differences between the tephra specific map changes between V1 and V3. I have been running 55580106 which installed and worked perfectly. So when I went V3 we went 55580306. I copied over my current tune, loaded it up but the timing and WGDC's are way off. I can't find much to confirm I have the tephra specific maps set up correctly. Any help would be greatly appreciated.
Old Jan 27, 2017 | 10:32 PM
  #260
eazlan's Avatar
Hi Tephra, I've send you one email to your address myforumnickname@gmail.com. Please advise.
Old Jan 27, 2017 | 10:46 PM
  #261
eazlan's Avatar
Need advised
yahoo bounce back.
is the email address correct?..really need help
Old Feb 1, 2017 | 01:19 AM
  #262
tephra's Avatar
lol...
its actually:
did_you_really_just_try_some_random_...name@gmail.com
Old Feb 1, 2017 | 04:09 AM
  #263
eazlan's Avatar
Hi Tephra.
I Manage to send you email...my email is inquiry about evo 8 jdm rom with SD Function and i did send all patch that ive tried.. 9417 and 9653
Old Apr 21, 2017 | 04:03 AM
  #264
poop2003's Avatar
Hi all,
I'm having problems trying to log the ethanol content to get my car ready for V3
I have a zeitronix ECA that i double checked the wiring and everything looks like it's connected to where is should be (pin112 for us aussies), but when i log in evoscan, it shows a value of 95 but my gauge shows 2%. My tank should be very low on e85 so i believe the gauge reading is correct.
I removed the ECA from the equation and disconnected it from the ecu, but logging still returned a value of 95. I also checked the voltage of the analogue output wire, and that read 0.11v and matches the 2% reading on the gauge.
I'm at a loss on where the issue is - maybe i stuffed up in evoscan? here is my evoscan setting.
Any help will be greatly appreciated! Thanks.
Attached Thumbnails Flex Fuel testing in TephraXMOD V3-image1.png   Flex Fuel testing in TephraXMOD V3-image2.png
Old Apr 28, 2017 | 08:43 PM
  #265
tephra's Avatar
as mentioned in email/the other forum (:P)... you need to flash V3 for that memory address to log correctly
Old Jun 8, 2017 | 03:39 AM
  #266
GP148's Avatar
Hi all, I have had an issue with the launch map function of V3. I am unable to have it switch. I have logged my timing and AFR targets and it is not changing from the standard map. Am I missing a step in activating this or is it not available or the sst. (Rom 56920008) I read other tephra mod threads and changed the max vehicle speed to 8 for launch maps. What else do I do?
Thanks in advance
Old Jun 9, 2017 | 10:19 AM
  #267
LOVEMYX's Avatar
Is there a Tephra v4 in the works??
Old Jun 14, 2017 | 04:42 AM
  #268
GP148's Avatar
what would you be looking for in a new version
Old Jul 15, 2017 | 10:50 AM
  #269
LOVEMYX's Avatar
rolling antilag
Old Jul 17, 2017 | 12:53 PM
  #270
naelzm's Avatar
im looking to purchase v3 for flexfuel options but looks like it doesnt support USDM EvoX MR 2012. any reason why its not supported? will it ever be supported in future? im guesing its a work in progress. tried to PM you but ur inbox full lol, hope to hear from you...
