Lean Spool AFR mapping table
Hey Merlin,
thanks for chiming in. Lemme know if you need anything
yah USDM 2005 only and still on the smaller 512K chip size.
Nonetheless i have had better luck with this and not the 96530006 or 96530706 universal ROM. no idle issues no p0505 issues. Just works...
Of course it is the one the car came with ( 2005 USDM MR 6spd 10.5 hotside)
OT a little but on teh LS trailing lean side the values are 9 9 9 9 4 5 7 12 10 11 11 1 1 1
From the LS threads, this controls the time going from the Base AFR to the AFR LS.
i interpret the trailing rich side to control the time going back to the Base AFR ( and therefore the high octane map). thse values are 9 9 9 9 4 3 3 2 2 1 1 1 1 1 which makes sense..ie get there fast if any issue comes up
So the question is : does the LS training time LEAN really just indicate the time spent in the LS AFR ...Seems to me it does if you consider the 12,10,11 values. I believe then if the ecu enounters knock it starts to control it and also drop back to the main AFR high octane amp and pull timing......
Is my thinking correct on this?
Thanks again for looking at the 96940011 ROM for all of us US guys wanting to use the LS feature
For those peeps following this, i am setting my LS AFR mapping about 0.2- 0.5 AFr higher thatn the base aAFR starting at 13.1. i edited the table to go to 9.0 base AFR with a 9.5 LS AFR then filled in from there.
This should be safe. but time and logging will tell.
Milburn
Milburn
Worked this out for 96940011
The LEAN SPOOL function has a 0-255 counter, which acts as an interpolation factor.
When the counter is at zero the full effect of LEAN SPOOL is in play and as the counter increments towards 255 the LEAN SPOOL effect is diminished until at 255 the ECU is running 100% on the Hi-Octane Fuel map.
Changing the interpolation counter increment step size will dramatically affect the LEAN SPOOL run time. For example, a step increment of 2 will halve the LS run time.
There are two step size parameters, one for LEAN SPOOL Decay when incrementing the counter, the other for LEAN SPOOL Reset when decrementing the counter.
Note that the counter can only be incremented (LS Decay) if the engine load is above the value in the LEAN SPOOL ACTIVE LOAD THRESHOLD table.
Conversely, it can only be decremented (LS Reset) when the engine load is below the LEAN SPOOL ACTIVE LOAD THRESHOLD.
The LEAN SPOOL DECAY STEP TIMER table sets the engine run-time for each counter step to be incremented.
The LEAN SPOOL RESET STEP TIMER table sets the engine run-time for each counter step to be decremented.
MUT 6C67
This is the timer scaling - with out the ends.
scaling name="Time(25mS)8" units="mSec" toexpr="x*25" frexpr="x/25" format="%.0f" min="0" max="6375" inc="25" storagetype="uint8" endian="big"/
<table name="Lean-Spool Load Hysteresis" address="127c" category="Lean Spool" type="1D" scaling="Load16"/>
<table name="Lean-Spool, Min Coolant Temp" address="127E" category="Lean Spool" type="2D" scaling="Temp16">
<table name="Temp" type="Static Y Axis" elements="1">
</table>
</table>
<table name="Lean-Spool Start RPM" address="1280" category="Lean Spool" type="2D" scaling="RPM8000">
<table name="ENGINE" type="Static Y Axis" elements="1">
Lean-Spool, Start RPM
</table>
</table>
<table name="Lean-Spool AFR Enable" address="1282" category="Lean Spool" type="1D" scaling="AFR16"/>
<table name="Lean-Spool Stop RPM" address="1284" category="Lean Spool" type="2D" scaling="RPM8000">
Lean-Spool, Stop RPM
</table>
</table>
<table name="Lean-Spool AFR Clip" address="1286" category="Lean Spool" type="1D" scaling="AFR16"/>
<table name="Lean-Spool Decay Step Time (from Lean to Rich)" address="3052" category="Fuel Lean-Spool" type="2D" scaling="Time(25mS)8">
<table name="ENGINE" address="5C22" type="Y Axis" elements="14" scaling="RPM"/>
</table>
<table name="Lean-Spool Enable Step Time (from Rich to Lean)" address="3066" category="Fuel Lean-Spool" type="2D" scaling="Time(25mS)8">
</table>
<table name="Lean-Spool Load Threshold" address="307A" category="Fuel Lean-Spool" type="2D" scaling="Load8">
</table>
<table name="Lean-Spool AFR v Base Fuel Map" address="308E" category="Fuel Lean-Spool" type="2D" scaling="AFR">
<table name="Base Fuel Map AFR" address="5C48" type="X Axis" elements="7" scaling="AFR16"/>
</table>
MUT 6C67
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
[QUOTE=merlin.oz;11521353]Worked this out for 96940011
MUT 6C67
quoted to be able to see this but you cant :-( see last post for the word file containing Merlin's work
MUT 6C67
96940011 LS definitions and interpretation from Merlin
Damn bug on here wont allow the posting of tables etc.....grrrr...
I was asked by Merlin to remove the file as it contained errors.....for those who want to edit their 96940011 xml then go up several posts to Jax posts. Those addresses are correct for the LS AFR Mapping which probably the most important anyways.
So his interpretation may be translatable to the other 8 and 9 roms as im sure that the code would be very similar, just different addresses. And for sure we now know more about how the LS actually works.
Kudos to Merlin...the wizard !!!!
the RPM8000 scaling noted is the same as the RPM scaling in the evo7base xml so that doesnt need renaming...this is for the start / stop rpm tables.
Still working my head around the decay/reset that Merlin defined but will post back once i get the hang of what to do and the effect of the changes
Milburn
Milburn
LS decay
here are the stock values from the LS decay Lean to rich (Load above Load threshold ) timer and LS Enable Rich to Lean ( load below threshold )timers for the 96940011. These are in mSec according to Merlin.
LS decay Timer 0-255 LS Enable Timer 0-255
RPM mSec RPM mSec
500 225 500 225
1000 225 1000 225
1500 225 1500 225
2000 225 2000 225
2500 100 2500 100
3000 75 3000 125
3500 75 3500 175
4000 50 4000 300
4500 50 4500 250
5000 25 5000 275
5500 25 5500 275
6000 25 6000 25
6500 25 6500 25
7000 25 7000 25
The other 8 and 9 roms should be similar in values
RPM mSec RPM mSec
500 225 500 225
1000 225 1000 225
1500 225 1500 225
2000 225 2000 225
2500 100 2500 100
3000 75 3000 125
3500 75 3500 175
4000 50 4000 300
4500 50 4500 250
5000 25 5000 275
5500 25 5500 275
6000 25 6000 25
6500 25 6500 25
7000 25 7000 25
Raceghost
Nov 18, 2016 03:10 AM
