3 port fluttering at target boost
Old Oct 31, 2015 | 06:47 PM
kaj's Avatar
kaj
i don't tune my own car, Jay @ Boosted Tuning does that.. but i like to learn stuff because i'm curious LOL.
so he'll be tuning my car soon... and i'm curious: when my car hits target boost, the 3-port flutters (i can hear it and my gauge bounces 3-4psi really fast) until the RPM goes up (not sure which RPM it settles), then it stays steady.
what could cause that? i want to be sure it's nothing mechanical so he can work his magic with no issues.
here are the duty cycle/error/PSI numbers:
100 0 2.1843
100 0 3.1203
100 0 3.8223
100 0 4.9923
100 0 6.6303
100 0 8.2683
100 0 9.9063
100 0 12.2463
100 0 14.3523
71 0 17.6283
65 0 21.1383
65 0 23.2443
65 0 23.2443
65 0 23.7123
65 0 23.0103
64.5 0 22.5423
64.5 0 22.0743
64.5 0 21.6063
Old Nov 2, 2015 | 06:35 PM
CDrinkH2O's Avatar
Wink Noisy 3-port?
It's quite normal to hear your 3-port rattling away especially if it is mounted directly on the frame rail. I isolated mine with a couple of rubber washers and it is much quieter now
Old Nov 2, 2015 | 07:55 PM
kaj's Avatar
kaj
Maybe. But it's never done it before. I would have noticed the boost gauge bouncing all over the place. It's always been dead still.
Old Nov 3, 2015 | 02:56 PM
desiromeo812's Avatar
turn the boost up you *****
Old Nov 3, 2015 | 03:17 PM
kaj's Avatar
kaj
1. untuned? bwahahhaha. nah.
2. my tuner won't tell me how and i don't understand the tutorials (they all seem to use older versions of EcuFlash) LOL. it's probably a good thing.
Old Nov 3, 2015 | 03:25 PM
LetsGetThisDone's Avatar
Post a complete log from excel, delete the timing curve so your tuner doesn't get mad. But its probably related to changing the turbo without updating the tune...
Old Nov 3, 2015 | 03:38 PM
kaj's Avatar
kaj
oh, most definitely. i'm not trying to fix it, he'll do that. i'm just curious as to what causes it. i'm always wondering "why?" and wanting to learn stuff. LOL.
even if i knew why it was acting weird, i wouldn't fix it myself. i know how hard Jay works on the tunes and i'm not going to mess it up.
Old Nov 3, 2015 | 06:16 PM
deylag's Avatar
Good one Gary lol
Old Nov 5, 2015 | 05:38 PM
Klaiceps's Avatar
Just trying to understand what's going on here. Is this under WOT or part throttle? Is your BOV fluttering? Is your car bucking/hesitating? Might be a compressor surge issue.
If that's not the case, is your boost holding stead after hitting target boost or is it fluctuating +/- 3-4 psi?
Old Nov 5, 2015 | 05:49 PM
kaj's Avatar
kaj
1. floor the car
2. all is well during spool up
3. when boost threshold is reached, i hear rapid fluttering and the gauge needle bounces like crazy.
4. as RPM continues to climb, it settles back to normal.
i emailed my tuner, with a log, on Oct 30. still waiting to hear back.
Old Nov 5, 2015 | 06:03 PM
Klaiceps's Avatar
1. floor the car
So your car doesn't buck/hesitate when reaching target boost? Also does boost taper off or is your target boost holding steady?
Old Nov 5, 2015 | 06:12 PM
kaj's Avatar
kaj
doesn't act weird at all.
boost tapers, but the tune is for the old turbo, so the duty cycle still needs adjusting.
the car isn't tuned yet. i'm just wanting to be sure the issue isn't mechanical. if it is, then i want to get it done before the car is tuned i.e. if it's a faulty WGA or DV, etc.
if it's simply an ECU tuning issue, then i can breathe a sigh of relief and wait for my new ROM.
Old Nov 10, 2015 | 10:37 AM
sbn1979's Avatar
Sounds like compressor surge what you are explaining. Have you tried dropping duty down to see if it stops it?
Old Nov 10, 2015 | 10:45 AM
kaj's Avatar
kaj
I don't usually mess with my tunes, but I will be tonight.
I'm at 100% until around 3500rpm, then drops to 65ish.
It's a larger-than-stock turbo on a stock.engine, so I never contemplated surge. I've never had it, so don't know what to look for.
Old Nov 10, 2015 | 11:04 AM
sbn1979's Avatar
Explaining fluctuations of the boost gauge like that tallies with surge. What's it like in part throttle? Overtaking ? I'd defo drop 100 duty down in 3-3500 rpm range and some where it's surging to see if it cures it.
