"RAX Patch Version 3 - Official and Latest"
Old May 12, 2018 | 07:46 AM
  #46
richardjh's Avatar
Originally Posted by ddlopresti
Sorry to bring this thread back from the dead, but i drove at 4500 feet this past weekend and noticed that i was under boosting by about 4psi and the turbo was spooling super late. Its possible my turbo just can't keep up, but what can i check in the tune/logs to make sure that the barometric sensor based boost is turned on properly and working?
When i got back down to about 2500 feet everything seemed to be working fine, but please let me know.
Hiya. The only thing the Baro Compensation patch does is revise the boost target... which in turn feeds into the Error Correction system. Baro Compensation patch won't affect spool-up, as that's all pre-target stuff.
In terms of checking the tune to see if it's set up properly, you need to be using Direct PSI-based Boost Control. The "Atmospheric Boost" constant needs to be 0. And the patch needs to be fully added/enabled (obviously!).
In your logs, review the "WGDC Correction". That's the error correction working. If you see a bunch of negative correction factor applied, EC is pulling boost down. If you don't see that, it's not.
Hope this helps!
Rich
Old May 12, 2018 | 07:49 AM
  #47
richardjh's Avatar
Also, there is a PDF attached to the first post - check out the section named, "Testing of RAX3: Atmospheric Boost Baro Compensation".
Rich
Old Jun 17, 2018 | 10:13 AM
  #48
ddlopresti's Avatar
OK, so it appears psi based boost control and the zero value are plugged in but How do I verify the rax patch is turned on and enabled? Could i send my tune file to someone to take a quick look?
I think either the patch was installed incorrectly, or the omni 4 bar value might be incorrect, but I'm pretty lost and not sure how to get this working at this point.
Old Jun 30, 2018 | 04:50 PM
  #49
richardjh's Avatar
Emailed you on this just now.
Rich
Old Jun 30, 2018 | 04:51 PM
  #50
richardjh's Avatar
Update - Added support for 56950008, updated the first post's attachment.
Rich
Old Jul 26, 2018 | 02:19 AM
  #51
aj6828's Avatar
i have a JDM evo x sst 2008 which has is 52370028 would you be able to make a patch for me thanks..
Old Sep 2, 2018 | 04:23 PM
  #52
OHM_Racer's Avatar
Richardjh, I just noticed that you have it listed as Untested, but 53600010.xml is missing on the download files.
Old Oct 3, 2018 | 01:50 PM
  #53
bigric09's Avatar
Originally Posted by razorlab
Do you also have smart EC turned on? If so, the upward correction will only kick in if the boost is dropping, never when it's rising or stable.
Also depends on values in your upward correction vs TPS table and standard correction table.
Where did you add the info for the V3 xml and the raxpatch? I cannot get the tables to show up unless i paste them directly into the XMOD V3 xml in which case everything else is missing.
Old Oct 4, 2018 | 11:27 PM
  #54
richardjh's Avatar
It can be a pain, yes. I believe you need to "chain" your include statements, with only one include per .xml file. If your XMLs are they type that go right down to the evo "base" file, try putting the RAX include in that. It's not ideal, but it will get you going.
I really wish ECUFlash was able to cope with multiple include lines in one xml!
Rich
Old Oct 4, 2018 | 11:29 PM
  #55
richardjh's Avatar
Would you be able to email me the stock ROM image for this? I don't have it. --> raxpatch {at} gmail {dot} com
Cheers.
Hmm, I will take a look - thanks.
Rich
Old Dec 13, 2018 | 07:01 PM
  #56
richardjh's Avatar
Updated list of ROM IDs reported as "tested successfully" (53040010).
Old Feb 12, 2019 | 09:01 AM
  #57
Roberto Sampaio's Avatar
How to Uninstall old RAX/RAX2 patches from my vehicle ROM. ?
Could you give me a setp by step?
Old Feb 13, 2019 | 03:26 PM
  #58
I try to find out if rax v1/2 is installed in my room using xvi32 editor but I don't know the address to verify.
could you help me?
I'm running 57140001 xmod v1
Old Feb 18, 2019 | 08:59 AM
  #59
sub7's Avatar
Have a look at this rax patch, find your rom ID and follow the instruction in the pdf to remove rax v1/2.
https://www.evolutionm.net/forums/ec...m-patches.html
Old Feb 27, 2019 | 06:27 AM
  #60
richardjh's Avatar
could you help me?
Hiya. How about you just email me the ROM image file. I'll check it out.
Cheers,
Rich
