"RAX Patch Version 3 - Official and Latest"
Old May 20, 2021 | 02:51 AM
  #76
Peter Pasenko's Avatar
Originally Posted by rabenne
1. Returns -49 C. Not sure we have the same internal addresses...
2. Did not try it yet, but will probably give it a whirl.
How did you come up with this? Resource? Guess and check? Thanks muchly!
One Russian guy shared with me info about SST Temp, and as for knocksum - I found it somewhere on evolutionm.net. And I forgot to mention - I have EDM Ralliart 2009 (SST reflashed with S-SPORT 2011 firmware) but I'm really surprised to hear about any differences in OBD codes.
Old May 24, 2021 | 04:33 PM
  #77
richardjh's Avatar
Hi folks.
I did find an "SST Temp" memory address a while back. It's used to trigger the SLOW DOWN message. It doesn't look like it's a true temp reading from a sensor, though; instead, it appears to be some calculated/simulated temperature value that the SST is giving the ECU... based on ~magic~ or something.
Still, it's slightly better than nothing, and it's able to be read using standard mode23 style logging.
I should be able to cross-reference from my "known" ROM image to other ROM images for this, and find the equivalent address for you. What ROM ID(s)? Hopefully I have the ROM images in question on file somewhere (but it's been a while!)
Rich
Old May 24, 2021 | 07:37 PM
  #78
rabenne's Avatar
52690322! Thanks man, you rock!
I am also having weird issues trying to get my rear o2 voltage to rear correctly. I was trying to log the rear o2 voltage (actually wideband analog output) as well as logging my wideband's serial output data, so that I could develop an accurate evaluation based on the calibration present in the controller. Seemed right in my head anyway...
I had to switch to golden 2008 USDM v1 EVOX in Evoscan to get it to read rear o2 as volts. In RAX patch as well as MODE 23 EVOX USA, it seems to have a multiplier applied or something. I see values between 0 and 300. certainly doesn't seem to be the proper 0-5v.
Using regular logging I got an eval of =2.3*[rearo2volts]+10.1 for the wideband. Gonna have to try it out... but still, any ideas why I get random numbers logging rear o2 with "x" eval with mode 23 and rax?
thanks!
EDIT:g
figured out I need the 255*5 expression in there and got it working pretty good. After a few revisions and rechecks, I landed on 2.46*[Rearo2volts]+9.72 and see data in the logs matching very closely. should be good enough...
Old May 26, 2021 | 11:41 PM
  #79
richardjh's Avatar
I don't have 52690022 ROM image, but I do have 52690021. If the logging addresses haven't changed across those versions, your "SST Temp" mode23 address should be 808744... 2-byte logging value. I use x-10 function to get Celsius.
Be aware that this number is probably DERIVED instead of some direct-from-sensor value, so it may be of questionable use. It does seem to be used to trigger the SLOW DOWN message, though.
See if this reads as something resembling a temperature!
Rich
Old Sep 25, 2021 | 04:39 PM
  #80
richardjh's Avatar
Here is the latest ZIP of all RAX-supported ROM XMLs. This includes 56940014 ROM ID.
I tried uploading this to the first post, but EvoM kept throwing an error. For now, this will have to suffice.
Rich
Old Feb 19, 2022 | 11:20 AM
  #81
Kooldino's Avatar
56900010 which inherits 56900009 does not work.
RAX IAT Adjusted BWGDC: Call Subroutine returns a "(no match)" as does RAX Direct Boost Baro Comp: Data and Subroutine
Old Aug 24, 2022 | 10:49 PM
  #82
Stavr1's Avatar
Does anyone have this RAX file: RAX Patch Ralliart SST v1r10: ROM 53610013. Links for download doesn`t work.
Old Oct 2, 2022 | 10:47 PM
  #83
bnio's Avatar
You will have to confirm if it will work with your rom but here is a zip of V3 from last year 2021.
Old Oct 2, 2022 | 10:53 PM
  #84
Stavr1's Avatar
Thanks, but i searching for RAX Patch Ralliart SST v1r10: ROM 53610013.
Old Oct 3, 2022 | 09:26 AM
  #85
RobbieOh's Avatar
5 Year Member
I don't think the RAX SST V1 has been released to the public yet, I could be wrong tho. I need it for my X 56900010 too
Old Sep 17, 2023 | 01:02 AM
  #86
axiscom's Avatar
5 Year Member
Can anyone tell me, if this works on a lancer cars, I get it to work on my ROM 59520005?(Outlander Sport)
richardjh, мuch respect for the work!
Old May 24, 2026 | 12:49 AM
  #87
Sizu-Cz4a's Avatar
JDM RAX Patch Version 3 を探しています
Hello, everyone.
I’m an EVO 10 owner living in Japan.
I’m looking for a RAX Patch for my 56190002 (2010 JDM GSR SST), but I can’t seem to find one.
I need it to log data using EVOSCAN.
I’d like to know where I can get one.
How much does it cost?
Thank you.
neddludd
Jun 12, 2020 05:37 AM
fireroasted
Aug 15, 2012 05:57 AM
Piro Fyre
Jul 15, 2011 05:54 PM
onboost
Jun 26, 2009 06:04 PM
EVOIXreno
Sep 22, 2008 07:05 PM
