OMNI 4 Bar with 96531706
Hi,
what needs to be adjusted to configure the 4 Bar Omni Map sensor to 96531706 (Tephra SD)?
found this thread
https://www.evolutionm.net/forums/ec...evo-8-9-a.html
but different rom versions and the table defs are removed.
found this thread
That is a universal rom for the evo 8. I did not have to adjust anything in the rom if I remember correctly. I am using 96530706. If you use a USDM rom though your car may not start unless you alter the values for the map sensor. All I did was verify the equation in Evoscan to make sure I was reading the correct boost pressure.
Hi,
found this thread
found this thread
Hi everyone,
There is a bug that is dropping text when the text editor encounters certain symbol combinations and words such as 'code'. The bug was introduced as part of a large software change and we hope to see a fix this week or next. Thanks!
You don't have one! It's normally mounted in the blanked out hole on top of the manifold. https://www.evolutionm.net/forums/at...hmentid=104120
Guess it's time to get an Evo 8/9 inlet manifold.
rr06rs
Jun 13, 2012 07:01 PM
magyar86
Nov 23, 2010 08:12 AM
