Benchflash fails
Old May 12, 2016 | 10:04 AM
CanEvoX's Avatar
Benchflash fails
Bricked my Ecu yesterday. Spent 7 hours benching it, still couldn't do anything.
Basically, it would bench it fine in alt mode. But when I right after try to flash in normal mode I get J2456 error timeout.
Should I use alt mode, then plug ECU into car then use normal mode? Or can I use alt mode, and then right after normal mode while ECU is still wired in manually?
EcuFlash version: 1.44 - Latest
Also, my tune was produced with version 1.39 and modifying it in any way in V 1.44 seem to brick ECU in the first place... any advise would be helpful.
P.S. Bricked my car 10 mins away from my home - broke the rule of never flashing unless in my garage.
Old May 13, 2016 | 09:58 AM
CanEvoX's Avatar
Figured it out.
I was on EcuFlash version 1.39 and the upgraded to 1.44, but for some reason it didn't upgrade the drivers properly. Un-installing, re-installing didn't help, so I grabbed another laptop and installed EcuFlash there. All worked smooth.
So it's wrong version J2456 driver.
Old May 22, 2016 | 09:41 PM
BlackHawk_Tsi's Avatar
Good to know thanks!
Bigasshammm
Apr 24, 2016 06:17 PM
evo3barboost
23
Jan 2, 2007 08:54 AM
evo3barboost
Sep 14, 2006 11:28 PM
mikiblueeyes
11
Mar 13, 2006 09:55 PM
Derek888
31
Nov 3, 2005 02:36 AM
