At a loss with Knock Sensor. Constant 8-9 under minimal/all loads
Old Jun 12, 2016 | 03:32 PM
03GS-T's Avatar
Hello all,
I'm having some knock sensor issues. I've pretty much verified its false via adding octane fuel from 91 to 98. My issues are:
Constant knock in any gear at any load over 2000rpm. Always 8-9 counts. Never more or less.
I've tried adjusting the Knock load values from 0 to 159 with no change.
This is on a recently turboed 4G64.
AFR's are good and Hi ignition values are reasonable. It switching to the low octane values just before showing knock
Thanks in advance
Old Jun 12, 2016 | 03:51 PM
wreckleford's Avatar
Your knock sensor is bad or unplugged. That's how the ecu responds when it doesn't get a signal form the knock sensor. You should eventually get a check light for the knock sensor.
Old Jun 12, 2016 | 04:26 PM
03GS-T's Avatar
I had read that and I did get a code. But, if I flash back to my stock 04 eclipse RS Rom, I dont have this issue on any octane. Even the recommended 87. Could it be the Tephra Rom?
I have a sensor off the spare motor I have, i will swap them and see! Thank you
Old Jun 14, 2016 | 07:35 PM
Asmodeus6's Avatar
Did this problem just start? Or you flashed over and it was boned from GO?
Car has / was running fine with old rom, this motor is new, etc? Background info can help others narrow down the direction they point you in.
Recently turbo'd, and currently about to blow apart engines make a lot of knock when things aren't right. Like when the bearings are in your oil pan.
I have had things as stupid as a T-bolt clamp touching the exhaust manifold and tinging just ever so slightly at certain RPM throw a ton of knock on a car before. So check all your rattly bits as well. Your old rom probably doesn't look at knock as uhm, seriously as one from an Evo. If the sensor is bad it will do exactly what it is doing tho.
Old Jun 14, 2016 | 08:01 PM
Biggiesacks's Avatar
have you verified the ecu pinout is the same between your stock ecu and the ecu from which the rom you are using came from? Just wondering if maybe the ecu is looking for the knock sensor on a different pin.
Old Jun 15, 2016 | 01:21 PM
03GS-T's Avatar
Thanks for the help. Ended up being a cut wire for the knock sensor. What was weird is I had no code/knock on the stock rom for 10k miles. It all happened when i loaded the tephra rom.
Strange as day but at least i can log knock now. Aha.
Thanks for the help! Great forum!
zigzagzok
Sep 5, 2013 12:49 AM
evo8dad
Mar 21, 2010 02:05 PM
Dragon-V
Feb 16, 2009 05:29 PM
FastEvoFL
May 10, 2006 09:43 AM
Z1 Performance
11
Jul 11, 2004 03:42 PM
