high knock sum count at low loads
Old May 28, 2013 | 07:55 AM
zigzagzok's Avatar
hi
Cld someone shed some light on my datalog?
Seems that I am getting lots of knock at loads 70+/- at gear 1 / 3 @ <2k rpm
possible that the knock sensor is picking some clutch chatter?
Can i safely ignore this?
Am driving an AUD SST..
Mods limited to pon-cams; grimspeed 3 pot.. still on stock air box.
much appreciated!
Old Sep 4, 2013 | 06:37 AM
Eshark's Avatar
Not sure of the answer, but I have the same problem. I can't hear the knock, but its detecting high counts.
Old Sep 5, 2013 | 12:49 AM
richardjh's Avatar
Normal for 4B11, it seems.
https://www.evolutionm.net/forums/ev...explained.html
https://www.evolutionm.net/forums/ev...-rpm-load.html
I put back the stock map on my RA one time, with nothing but Mode23 logging enabled... and took it for a drive in the hills. Put SST in dumb AUTO/NORMAL mode. Guess what -
Heaps of knock, load 60-70, 1200-2000 RPM. Factory tune, factory vehicle. Lots of knock, like 6-12 knocksum.
At these low loads, cylinder pressure is low. It's not going to grenade or anything, by all accounts.
This sort of thing is why tephra's "KnockCEL" ECU patch has a "Minimum Load for KnockCEL" value (normally set around the 100-load mark).
Rich
4b11slayer
Nov 1, 2016 02:38 PM
1UpMoto
Nov 5, 2014 01:16 PM
jcsbanks
Jun 21, 2013 03:29 PM
Evo1001
Feb 17, 2012 08:01 PM
jjayp
Mar 12, 2011 12:01 AM
