WGDC Fixes (what are they?)
Old Dec 7, 2016, 06:30 AM
3VOLUTIONIST's Avatar
So, I'm going through my v7 (90550701) and just trying to understand what each of these tables actually means. Ive got a whole bunch in the "Miscellaneous tephra mods" submenu that I have no idea what they mean. Would someone care to educate me please?
-Gear timing trim patch #1 (0x874F -> 0x8446) The current value is 20FE (Which apparently is equal to 8446 in hex)
-WGDC=100% fix
-WGDC fix 1
-WGDC fix 2
-WGDC fix 3
-WGDC fix 4
-WGDC fix 5
-WGDC fix 6
In global ignition settings there's also
-Ignition retard limit (self explanatory, however below it theres "timingRetared2"..)
In global fuel settings there's:
-Fuel cut multiplier
-Fuel cut load x1
-Fuel cut load X2
In global boost control theres RPM/Speed to gear, I've got a W5M33-2-NRBE trans, which obviously has different ratios to Evo boxes, so im not sure if i should be changing these numbers or not..
Ill probably find more as I work my way through, but thats it for now.
I tried to find a "tephra v7 tables explained" thread, but wasnt successful, so i apologise if this has already been covered somewhere
Couple of extras..
Tephramod options:
-Enable airflow calcs
-Enable manifold absolute pressure averaging
Old Dec 7, 2016, 12:25 PM
Raceghost's Avatar
I am thinking this might be the "Gear Based Boost" setting. Is it a single switch, only one field?
-WGDC=100% fix
This might be the WGDC 100% under "this" load value. Meaning the WGDC will stay at 100% till load in field reached.
The other ones I have never heard of before.
Could be secondary ignition retard tables for warmup.
-Fuel cut load x1
-Fuel cut load X2
These definitely are the double load and fuel cut multipliers for high boost. Stock is 319 or fuel cut load 1, fuel cut load 2 doubles this so above certain boost, you don't hit fuel cut.
On another note, List those other tables with memory addresses for each one. Maybe a screen shot of the actual tables within ECUFlash. Might help.
Old Dec 8, 2016, 03:49 AM
Im just using the standard 90550701 Tephra v7 ROM, and this XML
Fuel cut load x1 goes from 180 to 168%, from 3000rpm to 7000rpm
Fuel cut load x2 goes from 360 to 335 between the same rpm ranges.
File Type: xml
Old Dec 8, 2016, 12:47 PM
Raceghost's Avatar
Scaling for both of those seems to be off at first glance.
I also do not have a correlating ROM file to go with your XML, so attache a current ROM the way you have it please.
Old Dec 8, 2016, 07:07 PM
I have noticed certain values seem to make no sense
Am I allowed to upload 90550701? (considering it's a paid ROM from tephra)
Old Dec 8, 2016, 09:46 PM
Raceghost's Avatar
I wasn't aware of actual purchased ROMS. Most of Tephra's stuff was donation paid for. But again, not to step on toes, I guess ask him. Send him a P.M. If you want, email it to me, p.m. me. I use the 94170715 ROM so I'm not interested in it, and it probably wont work on the USDM EVO 8.
Old Dec 10, 2016, 07:20 PM
HyperDisorder's Avatar
This post should fill you in a little bit OP.
I don't know any more than that though. I did unsuccessfully try out the timing trim per gear on my 96260709 rom and as far as I know it does not work on any other rom either.
You could also ask donner what the WGDC fixes should be (as briefly mentioned in the linked post), but I think that he has priorities a little more important than in the Evo community these days (how dare he! haha).
Having said that, maybe Raceghost can work some magic.
Maybe I should relearn how to read disassembled code again, too... one day.
domyz
Sep 9, 2014 10:48 AM
prowakeskater
Apr 15, 2012 08:40 PM
avengerhed
May 26, 2005 09:08 PM
ILP Performance
Lancer Vendor Classifieds
50
Apr 14, 2003 11:54 AM
ILP Performance
Lancer Engine Tech
Oct 10, 2002 07:22 PM
Quick Reply: WGDC Fixes (what are they?)
