Can anyone look at my logs and help me out
Old Apr 22, 2017 | 04:11 PM
Evo_Goodness's Avatar
Okay but I'm still learning this lol so sorry if i sound dumb how should i copy that over size map that looks like a tephra v7 big map I'm still running stock rom I was trying to learn all I could before I jump onto tephra there is extra load cells and RPM cells so i know you say start at the 120 load and work over but won't that throw the timing all whack ?
Old Apr 25, 2017 | 09:14 AM
LetsGetThisDone's Avatar
Copy the columns and rows that you have. IIRC the stock load is multiples of 20 instead of 10. I don't recall rpm. I think its every 500rpm though.
Old Apr 25, 2017 | 10:06 AM
Oh okay that's what I figured but wanted to make sure before I did it I'll work on it tonight
Old May 1, 2017 | 11:55 AM
Have you tried this yet?
Old May 5, 2017 | 12:33 AM
Sorry man i am in the process of it been really busy with work i was sitting down tonight to work on it just now lol
Old May 5, 2017 | 06:35 PM
Well I got it all switched over I actually took the hole map and used it I just decided it was time to switch to tephra v7 anyway and from the 120load section up i pulled 4 degrees of timing and zero knock so now this weekend I'll fine tune it but the car feels so much better...
That stock map truly is garbage lol I'm seeing 12afr spool up and 11.6 wot and tapering down to 11.1ish at redline I will probably touch up the fuel map also....
Now the only other thing I need to figure out is the pig rich if I have to just move the car say a couple feet in stop and go traffic it has always done this like if I start to move and then have to stop my afr drop to 10.0 then bounce back to 15.1 and stay there hmm
Old May 23, 2017 | 08:43 AM
That swing rich when moving the car short distance is normal. You could try messing with the fuel cut delay, but as long as it's only momentary, I wouldn't worry about it. Glad you get the car running well.
Old May 23, 2017 | 11:57 AM
Ya it's running really good man only gotten to drive it a couple times so the richness is normal then huh what's the fuel cut delay do never messed with it
Old May 23, 2017 | 01:24 PM
It's the time it take for the ECU to shut the injectors off after you come off the throttle.
Old May 23, 2017 | 05:53 PM
Ya i have been reading up on it its a quick swing and the RPM stumbles from it like to 500 and picks back up to 950 where i have it set and when it does it my wideband swings and maxes out to 10.0 then settles back to 14.7/15.1 ish
Old May 23, 2017 | 06:53 PM
hey stupid question what tephra V7 are people running i used 94170015 V7 but is 96530706 V7 better seems like there is way more stuff in it and is put together better hmm
Old Jun 1, 2017 | 03:36 PM
SnailSpeed's Avatar
I am using the 2.0 version of the speed density rom, specifically 94172715. Originally I was gonna use the older version but thought it was weird that it didn't have a 3d ve map unlike the rom i'm using.
BoostWhore
AEM EMS
Mar 4, 2011 08:24 PM
Charlie_B
Sep 15, 2007 08:20 AM
rraulston
Apr 11, 2007 02:35 PM
