EVO X MR - TephraXMOD V3 - launch map - altmap
Old Oct 23, 2017 | 09:51 AM
  #31
ETS Michael's Avatar
If your getting the overheat warning then this probably won't fix it. There is something else wrong.
- Robert
Old Oct 24, 2017 | 05:32 AM
  #32
Jacblack's Avatar
I was hoping this would allow for longer stage times but I guess no one is clear on that. Just seeing if it were added benefits to the launch maps besides just spooling the turbo. For example in a GTR I can see on LC longer than what I’m able to do in the MR, just makes grudge racing a little easier at the track.
Old Oct 27, 2017 | 12:42 PM
  #33
franzcars's Avatar
You'll still get the error, it just lets you build more/any boost, but for grudge racing, would let you go in second and be up on boost faster
Old Oct 30, 2017 | 08:01 AM
  #34
I have yet to time my LC out on the MR. I have sat on it from the time it took someone to light up both bulbs and roll through the sportsman tree. It was probably about 5-6 seconds in total. Might be different for different years though.
- Robert
Old Dec 8, 2017 | 05:53 AM
  #35
npallavi's Avatar
Hey,
I have been getting my tune finalized for a
2008 X MR
Internal ID 53050312
Inherits 53050012
We have been trying to get spark cut and launch maps working together. My tuner said "brake switch - so i double checked the code - it's definitely "right" - but i chatted with some other tuners in the USA and we aren't convinced the launch maps are actually turning on properly on the sst cars."
Is this still an on going issue that's being resolved?
Thanks for any info or help.
Old Dec 8, 2017 | 10:36 AM
  #36
franzcars's Avatar
Originally Posted by npallavi
Hey,
2008 X MR
Inherits 53050012
Did you use my second patch to enable launch maps, or are you just using a standard v3?
Old Dec 8, 2017 | 10:20 PM
  #37
npallavi's Avatar
Hi Franzcars,
I was unaware of a second patch, Not sure if my tuner has patched the V3.
Old Dec 9, 2017 | 03:48 PM
  #38
franzcars's Avatar
Hi Franzcars,
By default launch maps do not work on v3, you need a patch to switch the clutch switch input from launch maps to the brake switch input
Old Dec 13, 2017 | 11:50 AM
  #39
GeoMitsu's Avatar
How can I/we get the patch ?
Do you mean the spark cut patch or something else ?
Thanks for your reply.
Old Dec 14, 2017 | 04:01 PM
  #40
franzcars's Avatar
It's a patch that enables launch maps using the brake switch instead of the clutch switch, but if you email me I'll see if I have it
Old Dec 15, 2017 | 11:53 AM
  #41
GeoMitsu's Avatar
I've sent you a private message probably it didn't reach ... !
Old Jan 29, 2018 | 09:37 AM
  #42
GeoMitsu's Avatar
Thanks franz for your help and support.
I confirm that the spark cut is working perfectly with the Tephra V3
Old May 24, 2019 | 12:49 AM
  #43
10isace's Avatar
I have 55580306, USDM 2010 MR. I'd love to get this working. Thanks!
Old May 23, 2024 | 01:45 PM
  #44
Aloosh1983's Avatar
hello, I need this patch can you sent it to me please
My email
Angelspace56@gmail.com
tephra
Sep 13, 2021 01:07 AM
eTiLiKo
Apr 18, 2017 01:55 AM
Lightsaber
Jul 30, 2015 07:57 PM
tephra
Mar 18, 2008 06:22 PM
