93660005 tephramod?
Old Oct 5, 2017 | 01:56 PM
merlin.oz's Avatar
The description, axis and scaling for the table on the left is totally wrong.
The right hand table is better as the axis is airflow Hz and it is best to use unit scaling for this table for our purposes. It is not a MAF scaling table though, rather a MAF constant table related to airflow pulse per stroke. This table should actually be left stock.
Essentially you are trying to deal with xml that have varying errors of scaling and description.
There are likely to be others buried in your xml too.
Old Oct 17, 2017 | 01:24 AM
TariqEvo's Avatar
Originally Posted by mines5
Well, I never had to do change that in any of the v7 roms as it was already disabled by default.
So I flashed the v7 rom, copied the immobilizer, ignition and fuel tables, but the car wouldn't start, no check engine light, it would crank over but not start.
Old Oct 17, 2017 | 08:31 AM
mines5's Avatar
Disable immobilizer from periphery bits.
HyperDisorder
Sep 16, 2021 10:54 PM
YaroRS
Apr 21, 2012 01:08 AM
EvoPower81
Oct 13, 2010 05:31 PM
claudiumxg
Jul 14, 2009 02:02 AM
Youngsyr
Oct 19, 2008 10:44 PM
