problems logging boost and afr in evoscan
Old Nov 14, 2017 | 08:57 AM
Evo8life's Avatar
hello guys just installed evoscan recently and im knew to using it my car evo 8 has aem uego afr gauge which I think already has white wire connected to pin 75 my problem is when editing the Eval and putting 0.03913*x+9 im not getting accurate afr with my gauge my gauge is at 15 and logged afr is 10 if I increase equation to x+15 afr becomes close but when my gauge drops to 14 my logged jumps to 16
Another problem whit my Omni 4 bar map sensor which is not calibrated in evoscan when I insert the eval and metric eval shown in previous threads around here
I get evoscan error RAX_DAT_D MUST preceed boost (map) move RAX_DAT_D TO above boost(Map)
anyhelp would be greatly appreciated
Old Nov 16, 2017 | 05:33 AM
Evo8life's Avatar
bumppp anyone can help please ??
Old Nov 16, 2017 | 03:00 PM
seeaich's Avatar
I would start off by confirming this.
Have you tried uninstalling Evoscan and re-installing it with 4bar values? Sometimes weird **** just happens in evoscan.
Also, through up a log.
Old Nov 16, 2017 | 04:47 PM
4b11slayer's Avatar
You should just buy a serial port adapter and log afr through it
Old Nov 17, 2017 | 08:23 AM
butte's Avatar
Are you using the rear o2 sim?
For you map sensor issue, post the formula and a screen shot of your ecuflash data items. Looks like it's expecting some value to be present before the MAP value is computed? I'm not sure
Old Nov 18, 2017 | 07:29 AM
Evo8life's Avatar
i attached 3 logs of wot pulls 4 BAR map sensor and afr are at right end of the page with values way off will confirm pin 75 connection tomorrow
Old Nov 18, 2017 | 07:30 AM
Evo8life's Avatar
where can I buy it and what does it actually do
Old Nov 18, 2017 | 07:44 AM
Evo8life's Avatar
the eval im using is 0.2369*x with psig as unit you check my logs if you don't mind
Old Nov 18, 2017 | 08:01 AM
mines5's Avatar
Please look at this.
Old Nov 18, 2017 | 09:06 AM
Evo8life's Avatar
thanks man ill try this equation and see what happens
Old Nov 19, 2017 | 04:12 AM
Evo8life's Avatar
the omni equation worked with -24.7 instead of 14.7
But still facing issues logging afr equation didnt worked should look to see if connection to pin 75 is already made
Old Nov 19, 2017 | 05:38 AM
mines5's Avatar
Try Pin 73
Old Nov 20, 2017 | 06:47 AM
Evo8life's Avatar
While searching ive found this connector with 2 black and bkue wire is that supposed to be a serial port connection for the afr?its right under the dash
Old Nov 22, 2017 | 10:51 PM
CDrinkH2O's Avatar
Yes. That is a serial port. God only knows what those wires are connected to though. You need to trace them back to whatever they are connected to.
Old Nov 23, 2017 | 10:14 AM
4b11slayer's Avatar
Yea thats a serial port. Figure out were those wires go.
Your gonna need to buy a belkin serial to usb converter also
