Alpha N tuning on DSM
if you arent boosted, you could try doing a sd conversion and plug in the tps in place of the map sensor. the ecm will use the map vs rpm table but map will actually be tps. not sure how well it would work, but could be worth a try.
My cars tps uses 4 cables and the map uses 3, one of them is gonna be left unplugged, the question is which one, and will it work with only 3?
I wanted to see if it was possible before going standalone. I like running with ITB's it sounds awesome, the car runs pretty fine at WOT apart of being a little lean and at idle is too rich 12-14 AFR, the down side is cruising, the car runs like total garbage and the AFR start going crazy. I almost sure that the problem is the SD Map calibration. I had to put some crazy number to get the car running, and my injector size is dialed at 250 and I have 630cc injector, but if I dial in 630 the car wont even start, it goes to lean.
Gaby estas utilizando vacum box? lo otro es que puedes tener problemas en la calibracion de tu map o el offset de los inyectores acuerdate que si el voltaje esta variando altera la mezcla. saludos puedes seguir mis trabajos o escribirme a mi pagina y con gusto te ayudo
Facebook.com/HTuningPR
Te voy a escribir personalmente por Facebook para entrar mas a detalles. La verdad es que estoy tuneando mi carro yo porq siempre me paso haciendole algun cambio y me sale mas economico comprar el programa y aprender porq eso consume mucho tiempo y dinero. Y pues ademas me gusta hacerlo, es un reto para mi y siempre me ha gusto eso.
tsidrift1
29
Jun 26, 2010 08:53 AM
97EclipseGSX
30
Dec 22, 2008 02:21 PM
