Tuning not affecting the car.
Old Apr 29, 2018 | 05:02 PM
Cornedevo8's Avatar
I have a 2003 evo 8 and today I went out to tune so I could clean up my fuel trims and make sure my fuel maps were good. Anyway while I was adjusting the injector scaling and the injector latency base, nothing was changing on my datalogs. I drove around for a good hour after I changed these values.
Second i went to do a pull on the on-ramp of the freeway and my AFR were completely wrong. In the high octane fuel map I’m supposed to be around 11.5 at WOT. But instead I started at 12.2 and it’s started to climb up to 12.9 in an instant so I let off around 5k rpm.
Anybody know what could could be wrong or affecting this?
Old Apr 29, 2018 | 06:01 PM
ronaldo9's Avatar
Which way did you scale your values? What is your duty cycle? What fuel are you using? The more info you provide the more people can help.
Old Apr 29, 2018 | 08:17 PM
Cornedevo8's Avatar
I’m running 1000cc injectors on 91 currently. So I decreased my injector scaling from 713 to 696. And I increased my latency. I don’t remember those numbers but my goal was to richen it up. My duty cycle is hitting between 45-52%.
Im on evo 9 turbo, bigger fmic, hks 272 cams, 3” TBE. Stock maf but 3” intake. And the bosche 1000cc injectors. I’m hitting 25psi Of boost.
Old Apr 30, 2018 | 05:47 AM
ronaldo9's Avatar
How old is your fuel pump and what pump are you using? How old are your injectors and are they clean? That would be where I would look first.
Old Apr 30, 2018 | 06:43 AM
Cornedevo8's Avatar
I am using a 310lph aem fuel pump and it’s about a year old. And my injectors are about 8 ish months old. And I don’t know if they are clean or not. I always run chevron in it. I’ll try getting some cleaner through them tho and see if that helps.
Old Apr 30, 2018 | 10:07 AM
Biggiesacks's Avatar
any chance your running on the wrong map (Alt map)?
Old Apr 30, 2018 | 11:08 AM
Cornedevo8's Avatar
I guess it’s possible. How do you switch from main map to alt map?
Old Apr 30, 2018 | 01:13 PM
depends on how you have it set up, because you have an 03 it could be the ICS switch, gas pedal, or an input on the ecu.
Old Apr 30, 2018 | 10:59 PM
Cornedevo8's Avatar
By any chance if the O2 sensors were ****ty, would they stop the car from going into closed loop? I don’t have any check engine lights but I have a hunch that they could cause an issue like this.
Old May 1, 2018 | 06:01 AM
ronaldo9's Avatar
Do you have a cable and evoscan? You can log the front 02 to see if it's dead or acting funky? How is the car driving in general. not just at WOT.
Old May 1, 2018 | 06:44 AM
Cornedevo8's Avatar
it drives just fine. No problems or anything. It richen out like it should under half throttle or so, it’s just at WOT. I looked at my data logs (yes I have a cable and evoscan) the Short term fuel trims are just reading -25. And don’t change at all and the LTFT(M) will read-25 until I press on the gas and it will change to +25. So I feel like those are my problems.
cool_as_crap
Nov 18, 2011 06:13 AM
EVIL_EVO_VIII
18
Oct 28, 2006 01:58 PM
Blue#2
21
Sep 29, 2004 05:17 PM
x7eVoLuTiOn7x
10
Dec 7, 2003 07:48 PM
