JDM EVO X ECU all options greyed out
Old Sep 2, 2019 | 06:28 PM
Llew's Avatar
Im still new to the EVO X and ECU Flash, I have a tactrix open port 2.0 and have hooked it up to the car to read the stock ROM, however all of the ecu options are greyed out and wont allow me to edit anything in the map. User level is already set to developer. Please need help asap as the factory tune is picking up a bit of knock here on reg pump fuel since its not 100 oct like in Japan. Memory Model: M32186F8 car is 2008 EVO X GSR SST Premium.
I may be missing something simple, please help
Old Sep 3, 2019 | 03:55 AM
crimson red's Avatar
Hi,
What is the version of your ecuflash?
Could you read a rom file from your car via ecuflash and saved it?
If you could, you should be able to see you rom id. What is your rom id?
Have you already installed definitions (especially for your rom id)?
For example, definitions are be able to be downloaded at RALLInspired.
If you have already installed the definition for your rom id, ecuflash should display maps of your rom automatically.
Old Sep 5, 2019 | 10:17 AM
Llew's Avatar
Thank you for your help. I was able to download the home, at first it downloaded in .SRF I then changed it to.BIN to see if that made a difference. I am able to download the file and test read/write. Im not sure about the definitions in the correct folder. At the time when I usde ecuflash I dont even think the evo X had come out as yet. My car information is showed under ROM info . ECUID and Case ID are blank. Internal Id: SM5237, flashmethod:mitsucan,memorymodel:M32186F8,Inherits :SM5236
Old Sep 6, 2019 | 05:45 AM
If you mean that after reading the rom from your ECU, you saved it as .SRF and renamed the file to .BIN by hand(for example, renamed using explorer), that is not good.
If you mean that first after reading the rom from your ECU, you saved it as .SRF and second after reading from your ECU, you saved it as .BIN, that is no problem.
I guess you mean all of the ecu maps(tables) of your rom are grayed out as if your user level is not set to developer.
Usually, when a rom is opened with correct definition, and user level is set to developer, maps(tables) are not grayed out.
Below is the steps to try to solve the issue(my recommend).
First, check your ecuflash version. If the version is older than 1.44.4799, download 1.44.4799 and install it cleanly.
Then, install all definitions on the site that I showed in my previous post(RALLInspired) to your 'rommetadata/mitsubishi/evo/' folder.
e.g.
Download all definitions on the site that I showed in my previous post.
If your 'rommetadata' folder is set to 'C:/Users/your user/Documents/EcuFlash/rommetadata/',
paste all of the definitions into 'C:/Users/your user/Documents/EcuFlash/rommetadata/mitsubishi/evo/'
(See File/Options/rommetadata. 'rommetadata' folder is defined there.)
Restart your ecuflash and open your rom that you readed and saved. Check whether the issue solved or not.
If still not solved, attach your stock rom that you readed to your next post. We can check it. (I guess your ROM ID is 523700**.)
Old Sep 7, 2019 | 09:49 PM
Llew's Avatar
I have tried all of these steps with no success.Including updating ECU flash downloading all of the rom definitions, making sure the rommetadata directory is set to the right location and also user level to Developer . Please see attached for ROM i was able to download from the cars ecu. Thanks again for your help.
File Type: bin
Old Sep 8, 2019 | 05:03 AM
Llew's Avatar
Internal ID:52370028
Memory Model:M32186F8
I notice there is No 52370028 xml file in the rommetadata directory EVO folder theres only a 52370023 and 52370024, there is no 52370028. COuld this be my problem? And where can I find this file?
I have attached the rom pulled again from the ecu this morning just incase i messed up with the previous version.
File Type: bin
Old Sep 8, 2019 | 08:29 AM
Metal_AF's Avatar
Yes, that's your problem, no rom for ECUFlash to reference. Unfortunately, I don't know where you can grab a copy :/
Old Sep 8, 2019 | 08:48 AM
Your ID is 52370008. As you noticed and Metal_AF wrote, there is no definition for 52370008 on rallinspired.com.
Attached is the definition for 52370008. Paste the file into your 'rommetadata/mitsubishi/evo/' and try it.
File Type: xml
Old Sep 8, 2019 | 11:56 AM
Llew's Avatar
THANK YOU!!!! it worked!
ifur
Sep 10, 2018 02:01 AM
Dakota Evo
Apr 14, 2015 01:48 PM
dspize
Mar 15, 2014 09:59 PM
ssabir22
May 9, 2012 03:33 PM
tato_dc
Dec 19, 2007 01:03 PM
